Sherwood Preamp and Power amp
Item Condition: Good
Shipping Options: Pickup available and you can audition.
Suburb or Town: Eltham
State: VIC
Payment Method: Cash
Reason for selling: NLR
Selling a Sherwood AVP 8500G pre amp processor and a Sherwood AM8500G power amplifier. They sound fantastic together.
The cosmetic condition is 7/10 as they have a few scratches. The front face plates are in a good condition and they look good as a pair (lol).
Pre amp Specs:
Power output: 50 watts per channel into 8Ω (stereo)
Surround output: 50W (front), 100W (center), 50W (rear)
Frequency response: 10Hz to 80kHz
Total harmonic distortion: 0.5%
Input sensitivity: 2.5mV (MM), 160mV (line)
Signal to noise ratio: 75dB (MM), 98dB (line)
Channel separation: 57dB (line)
Speaker load impedance: 8Ω (minimum)
Video Connections: composite
Dimensions: 440 x 140 x 380mm
Weight: 12kg
Power amp specs:
Specifications
Power output: 200 watts per channel into 8Ω (stereo)
Frequency response: 5Hz to 150kHz
Total harmonic distortion: 0.04%
Damping factor: 150
Input sensitivity: 1V
Signal to noise ratio: 120dB
Speaker load impedance: 2Ω (minimum)
Dimensions: 440 x 150 x 400mm
Weight: 22.5kg
The power amp has a broken rca plug and a hum.
The Pre amp works well and comes with a huge remote.
Selling with the pre amp as working and power amp as needing repairs.
Open to reasonable offers.
Pickup at Eltham only as the amp is heavy.
Edited by VKP1976
Price drop
