MP0001 Posted January 29, 2024 Posted January 29, 2024 (edited) Further Information: Van Den Hul D501 Silver Hybrid 1m RCA Cable. Purchased brand new approx 6 months ago. No kinks or hard bends, no original box but will be well packed. This is not the less expensive D501 Hybrid, it's the D501 "Silver" Hybrid. If you have done your reading then you'll know it was made as a special product for SME. Some info below - The D – 501 SILVER HYBRID is regularly used as a microphone cable in critical professional recordings and as a special product for SME in England together with their prestigious tonearms which on customer request can be fit with this silver version of the D – 501 HYBRID. The 2 signal lines are made each of 19 x 0.1 mm. highest grade Matched Crystal Silver strands. The signal line insulation with the colours white and red is made of cell-PE, so the stripping can even be done with your fingernails to prevent damage of the silver strands commonly caused by mechanical stripping. The resistance per signal lead is: 11.9 Ohm/100 meter. The capacitance between the 2 signal leads is a very low 58 pF/meter. The hybrid shielding consists of a dense and very pure silver coated high grade Matched Crystal (MC) OFC 72 x 0.1 mm. wire helix with underneath a Linear Structured Carbon ® (LSC) saturated conductive sub-jacket. The resistance of the shielding is: 3.2 Ohm/100 meter. The very flexible black outer jacket is made of migration-free HULLIFLEX ® to prevent any chemical deterioration over a long period. Edited February 8, 2024 by MP0001
