DdDesign Posted December 29, 2023 Posted December 29, 2023 I am hoping someone can guide me as to the best way to attach an Anntenna to a 1976 Yamaha tuner to get Am and fm reception. I have a tv anntenna on the roof. Can I somehow connect to that? I have attached a photo of the back of the tuner. Thanks in advance
wen Posted December 29, 2023 Posted December 29, 2023 If your TV antenna connection is close, you could put a splitter there and run a 75 ohm lead from the left side 75 ohm input on the back of the tuner to it, or, you could make an ariel, youtube has many videos on how to.
DdDesign Posted December 30, 2023 Author Posted December 30, 2023 14 hours ago, wen said: If your TV antenna connection is close, you could put a splitter there and run a 75 ohm lead from the left side 75 ohm input on the back of the tuner to it, or, you could make an ariel, youtube has many videos on how to. Thanks, yes the aerial is close. I’ll try it.
bob_m_54 Posted December 30, 2023 Posted December 30, 2023 (edited) Here is the connection diagram from the CT-810, which is the same. And yes, as @wen says, you could use the TV antenna into the 75ohm socket. Edited December 30, 2023 by bob_m_54 more
DdDesign Posted December 30, 2023 Author Posted December 30, 2023 2 hours ago, bob_m_54 said: Here is the connection diagram from the CT-810, which is the same. And yes, as @wen says, you could use the TV antenna into the 75ohm socket. Thanks, looks like I can get Fm from tv Antenna and need a separate am antenna. 1
audiofeline Posted February 25, 2024 Posted February 25, 2024 From memory The AM antenna is just a length of insulated wire, but it is directional (ie, it needs to be horizontal in a particular direction for best reception). No need for it if you don't listen to AM. I've used a splitter on the TV antenna for the FM tuner wherever possible. However, I do believe that there is a difference between a TV antenna and a FM radio antenna. The TV antenna is often very good, but a dedicated FM antenna I believe gives much better reception, and could be a consideration if you live in a poor reception area and the TV option doesn't work as well as you hoped.
DdDesign Posted February 25, 2024 Author Posted February 25, 2024 11 hours ago, audiofeline said: From memory The AM antenna is just a length of insulated wire, but it is directional (ie, it needs to be horizontal in a particular direction for best reception). No need for it if you don't listen to AM. I've used a splitter on the TV antenna for the FM tuner wherever possible. However, I do believe that there is a difference between a TV antenna and a FM radio antenna. The TV antenna is often very good, but a dedicated FM antenna I believe gives much better reception, and could be a consideration if you live in a poor reception area and the TV option doesn't work as well as you hoped. Thanks for the tips.
