Monitor Audio Silver 300 speakers (6G)
Item Condition: very good
Shipping Options: Pickup available and you can audition.
Suburb or Town: Melbourne or Frankston
State: VIC
Payment Method: cash on collection
Reason for selling: also have the 500's
Multi-award-winning Monitor Audio Silver 300 floor standing speakers. Fantastic sound from the brand that consistently punch above their price range. 6th Gen (2020), 2x 6”, 1x 4” with C-CAM gold dome tweeter.
Can deliver between Melbourne and Mornington. You are welcome to audition in Frankston or collect from Brunswick. Will include 3m bi-wired speaker cable.
Reviews
https://www.theabsolutesound.com/articles/monitor-audio-silver-300/
https://totallywired.nz/loudspeakers/monitor-audio/monitor-audio-silver-6g-300s/
https://www.monitoraudio.com/en/support/past-products/silver-6g/silver-300/
Specs:
The full three-way design delivers class-leading mid-range, while a pair of long-throw 6-inch bass drivers work together to produce incredible power from the tall, but slim cabinet design, making it the perfect choice for serious audiophile and AV installations.
The three-way configuration allows each driver to be optimised to do a better job over a narrower frequency band; the only real way to deliver elevated performance in every respect. Superlatively natural mid-range comes courtesy of a dedicated 4-inch driver, specially designed with ‘under hung’ voice coil and motor system. This technique ensures the voice coil always remains in the magnetic gap under all conditions for demonstrably lower distortion than usually found at this level – an advance which can be immediately heard.
Coupled with higher overall impedance and better overall system damping, the cabinet can be placed close to a wall. However, this is a serious audiophile speaker, capable of delivering seismic levels of bass extension. For optimum performance, a distance of just 12 inches (30 cm) is needed between the speaker and wall, allowing the system to breathe and perform optimally. High overall sensitivity makes this new Silver 300 easy to drive with a modest, high-quality amplifier delivering precise, dynamic music or film to fill a medium to large room.
System Format                        3-way
Frequency Response (-6 dB)  32 Hz – 35 kHz
Sensitivity (1W@1M)            90 dB
Nominal Impedance               8 ohms
Maximum SPL                        116 dBA (pair)
Power Handling (RMS)          200 W
Recommended Amplifier       80 – 200 W
Bass Alignment                      Bass reflex. HiVe II port system
Crossover Frequency              LF/MF: 570 Hz, MF/HF: 3.5 kHz
Drive Unit Complement         2 x 6" C-CAM RST bass driver
1 x 4" C-CAM RST mid-range driver
1 x 1" (25 mm) C-CAM Gold Dome tweeter
Cabinet Dimensions               1000 x 185 x 300 mm
Weight (each)                         20 kg
Further Information
