onetaste Posted October 31, 2023 Posted October 31, 2023 I am buying my parents a 65" TV and they want to mount it on the wall with a cantilever/articulating wall mount. My reading of the customer reviews on various products reveal complaints about the TV not staying level as soon as one rotates it away from the wall. Are there any that stay level when rotated out from the wall at an angle of say 30 degrees?
Snoopy8 Posted October 31, 2023 Posted October 31, 2023 Have Selby bracket for 60" plasma. It stays level when rotated (and came with a level to guide the install) https://www.selby.com.au/tv-brackets-stands/tv-brackets-and-mounts.html 1
Guest Posted November 14, 2023 Posted November 14, 2023 You get what you pay for with TV mounts. I've had cheap ones and expensive ones, and staying level and staying put when extended are definitely features of the better mounts. 2
Ariki Padlie Posted November 14, 2023 Posted November 14, 2023 1 hour ago, Marc said: You get what you pay for with TV mounts. I've had cheap ones and expensive ones, and staying level and staying put when extended are definitely features of the better mounts. Have to agree with that. For larger TVs ie 65" plus i would pay extra for a decent one. 2
onetaste Posted November 16, 2023 Author Posted November 16, 2023 Thanks for your advice. My parents have decided to mount it fixed to the wall. They went with a 77" LG G3. This will look much better. 1
Bass13 Posted January 18 Posted January 18 (edited) On 31/10/2023 at 7:34 PM, Snoopy8 said: Have Selby bracket for 60" plasma. It stays level when rotated (and came with a level to guide the install) https://www.selby.com.au/tv-brackets-stands/tv-brackets-and-mounts.html looking at getting a 55 inch TV, my problem is my internal cabinet size, as it will only fit a 48 inch.. So I'm thinking of buying a TV Wall Mount Corner Pivot Bracket, and bolt it to the back of my cabinet which is very sturdy....& is 600 deep. Not many brackets out there that I've seen extend out more than 500, this one comes out to 623, which in theory should work. https://www.selby.com.au/bracket-finder/37-60in-slimline-corner-bracket-plb126b-bl.html If anyone knows of any Pivot Brackets that extend further than 623, please advise. Found one @ 650.... https://www.selby.com.au/bracket-finder/37-60-led-plasma-lcd-tv-slim-wall-mount-bracket-with-pivot-bplb136b.html For anyone else looking for that extra length... And the largest I've found... Brateck LPA49-483XLD Extra Long Arm Full-Motion TV Wall Mount $135 https://www.pccasegear.com/products/61615/brateck-lpa49-483xld-extra-long-arm-full-motion-tv-wall-mount?srsltid=AfmBOooJiGyW2nhuKAubNZXMNOQyxy7bW3I_wBKog-1nRHVAZ1xuxhld_5Y Edited January 18 by Bass13 update info
