IGNORED
Martin Logan Stage Electrostatic Centre Channel
Item Condition: Mint 9.5/10
Shipping Options: Pickup available and you can audition.,Shipping is available at agreed cost.
Suburb or Town: Kenmore
State: QLD
Payment Method: EFT, Cash on Pickup
Reason for selling: No longer required
Further Information
Up for sale is my, a mint Martin Logan Stage electrostatic centre channel, which is finished in beautiful cherrywood. The Stage (not Stage X) is in perfect working condition and to me, perfect cosmetic condition. The rating of 9.5/10 given is due to the Stage simply not being brand new. The Stage RRP was circa $2,995 (USD) when in distribution and while subsequently replaced by the Stage X, which looked identical, the new Martin Logan centre channel, the 'Illusion' is a serious investment at $12,995 AUD RRP. I no longer require this great centre channel, as I purchased it when I had some Martin Logan Summits in Cherrywood and now have in-wall centre channels. Unfortunately, I do not have the original box for shipment, however I am sure I can organise something to safely transport it in at the purchasers cost. This item has also been listed elsewhere. Happy to answer questions.  Please see the Martin Logan Stage specifications below:
Frequency Response: 69–22,000 Hz ±3dB
Recommended Amplifier Power: 20‒500 watts per channel
Horizontal Dispersion: 30°
Sensitivity: 90 dB/2.83 volts/meter
Impedance: Nominal: 4 Ohms - Minmum: 2.9 Ohms . Compatible with 4, 6, or 8 Ohm rated amplifiers.
Crossover Frequency: 450, 2700 Hz
High Frequency Transducer: 1" (2.5cm) neodymium soft dome
Mid Frequency Transducer: Patented CLS™ XStat™ electrostatic transducer » Panel Dimensions: 7.5" × 18" (19.1 × 45.7cm) » Radiating Area: 135 in2 (873 cm2)
Low Frequency Transducer: Two 6.5" (16.5 cm) cast basket, aluminum cone with extended throw driver assembly, non-resonant asymmetrical chamber format
Components: Custom-wound toroidal audio transformer, air core coils, polypropylene capacitors
Inputs: Custom 5-way binding posts
Weight: 17.7 kg
Dimensions (mounting bracket/stand beneath speaker): 30.4cm × 87.9cm × 26.1cm
