anewmission Posted April 11, 2023 Posted April 11, 2023 Hello All, I am re-arranging my living room and would like to have my tv over the other end of a very large room (10m x 10m) The foxtel outlet is the only thing that is keeping me from doing this. The walls and room are extremely difficult to get into. (however i know there is always a way, though i am not an electrician) can anyone suggest a 4k wireless transmitter that wont have a problem with hdcp? or is there any other way? i dont have ethernet in this room either. only a ethernet over powerline socket which is plugged into an old router which is now an extender. Looking forward to hearing your opinions. Also, has anyone else had trouble getting 9hd and other FTA channels on foxtel iq4 box? Kind Regards
Guest Posted May 26, 2023 Posted May 26, 2023 While they do work, they can be unreliable. I played with loads of different solutions with a similar scenario to you a few years back. In the end, I spent more than I would have just getting a sparky in the first time.
