bwhitesox Posted October 31, 2013 Posted October 31, 2013 (edited) Item: JJ Acoustics - Premium Power Cable 1.0mLocation: Kew/MelbournePrice: $80 ShippedItem Condition: As NewReason for selling: Not NeededPayment Method: Sent via reistered post, Bank Transfer, Paypal.Extra Info: JJ Acoustics - Premium Power Cable - Premium Grade - 7AWG Pure Mono Crystal Copper - AC Power CableAC and IEC plugs have been Cryo'd to -126 Degrees Celsius (-195 Degrees Fahrenheit) for 48 hours to structurally align all molecules for best signal transfer.Pure Mono Crystal Copper (99.99999%) is similar to OCC copper, both of which are far superior in sound performance than OFC copper.Mono Crystal copper has sound characteristerics similar to silver conductor cables but with more bass response and a more natural sound.Cable offers 100% shielding from AC source to component input.Construction:Please see pictures for construction.3 x 7AWG Pure mono crystal copper conductors coated in teflon.German designed power cable.Made in Melbourne, Australia.17mm Total Cable Diameter.Double shielded - copper foil and tight copper braid.AC and IEC connector housing is made of thick military grade aluminium for 100% shielding from connector to connector. 99.9% of power cables are not 100% shielded as the connectors are not shielded! Full shielding provides a much quieter background for music to flow out of. It also enhances ambient detail retrieval and helps to improve bass response.The Conductors and AC, IEC connections cleaned with De-Oxidising contact enhancer.AC and IEC Plugs are sealed to ensure that the connections do not loosen over time and to prevent oxidisation.Cable can be easily bent.Requires approximately 20 hours to break in and to sound its best with performance improving from this point on but in subtle ways up to 100 hours.Approximate weight is 800grams for this 1m power cable.Rated for safe use up to 20Amps and 250V AC. Tested to easily sustain up to 600V AC, continuous.Pictures: Edited October 31, 2013 by bwhitesox
kczar01 Posted November 1, 2013 Posted November 1, 2013 ok let me know if falls through i will take it Thanks
wolster Posted June 9, 2014 Posted June 9, 2014 Congratulations on the sale of your item. If you feel you have benefited from using this system for the sale of an item through our classifieds system then please consider making a donation. Donation Payment Options You can make a donation via Paypal (using Credit Card or Paypal Balance), or Direct Deposit. Click below to make a donation: Thank you, your support is appreciated and every dollar makes a difference.
