milkafromdtv Posted March 1, 2023 Posted March 1, 2023 Further Information: Great pair of Paradigm surrounds / rears, excellent condition, been in storage for a few years but have tested them extensively. Would use them myself but the wife has said absolutely no more speakers to be added to existing setup. Design : 5-driver, 3-way bi-directional surround/rear Crossover : 2nd-order electro-acoustic at 2.3 kHz Frequency Response : On-Axis ± 2dB from 90 Hz - 20 kHz Frequency Response : 30° Off-Axis High Frequency Driver : Two 25-mm (1 in) dome tweeters, ferro-fluid cooled and damped Mid/Bass Frequency Driver : Two 140-mm (5-1/2 in) cones, 25-mm (1 in) voice-coils, oversize ceramic / ferrite magnets Low Frequency Extension : 53 Hz (DIN) Sensitivity : Room / Anechoic 90 dB / 87 dB Impedance : Compatible with 8 ohms Suitable Amplifier Power Range : 15 - 175 watts Maximum Input Power : 120 watts Finish : Black Weight : 6.32 kg each Dimensions HxWxD : 27cmx 33cm x 16.8cm
buddyev Posted March 20, 2023 Posted March 20, 2023 This advertisement has been withdrawn or the offer has expired.
