I'm after a US to AUS adapter. Is there anything a little better than the travel adapters you find at airports?
The best I have found is these:
http://www.vhaudio.com/images/vhaussie.jpg
I ordered some from addicted2audio but they arrived today and they only take the top two prongs of the US plug and the aus plug only has the top two prongs as well.
By only using the top two prongs of the us and aus sides what difference does this make if any?
thanks for any comments
I have seen the ones that Addicted to Audio sell and they are good quality. Obviously they are designed for Double Insulated products which do not require an Earth Pin
CAREFUL!!
The items shown are plug adaptors, not power adaptors, and will do nothing about the voltage mismatch.
Plugging a 120 volt US appliance into our 240 volt supply will likely have very sad consequences.
Greg
Hi Greg
Appreciate the wise warning!
I have 2 monobloc amps which i have aftermarket power cables for. The amps are 240v so no conversion required. I just need an adpapter so i can plug my US style power cables direct to the wall.
The adapters i have purchased have only 2 prongs on the aus side for plugging into the wall so i'm wondering what difference that will make, and also how to know if my amps should have the earth pin?
Thanks!
CAREFUL!!
Greg
Well worth mentioning.  The UK has 240V which is why I buy from there and not the US.
Hi Greg
Thanks!
ever thought of just re-terminating your power cables
I see you are in NSW
PM Cameron from krispy kables, a member and sponsor on here and get him to re-terminate your cables with some nice aussie plugs instead of using cheap travel adaptors
Hi Greg
Thanks!
If the current plugs have only two prongs then (theoretically) the amps are double insulated and don't need & probably shouldn't have ground connections. I used to use a pair of pliers to bend the twin prongs to the correct angle for Australian sockets and never had an issue.
If they have 3 prongs the best option is to change the plugs over rather than use an adaptor. If you know how to do it, fine. If not, get a friendly sparky to do it for you.
Greg
Guest Multidimension
Um Greg, when you bend the pins on a US 2-pin plug and plug it into an Australian wall outlet, to what do you suppose the fuse inside the amplifier is connected?
