I have a Cyrus 2 amplifier that hadn't been used for over a year. It seems to have a problem on the left channel - distortion and sound fading intermittently in and out when using the MM phono inputs.
Would appreciate any advice as to what may be the problem.
Interesting.
I have the same sort of issue with a Cyrus Pre. Odd things only from left channel and only when using the phono input. I posted here about it but no answer that have a solution. One thing I found in all my Internet searching was an issue someone had with left channel noise through a Cyrus pre. It boiled down to a faulty op amp chip. Maybe a replacement might sort your issue. I am about to do that with mine. The Pre has an NE5532P 8 pin op amp of that helps and saves you cracking open your 2.
Swap the turntable leads and see if the problem changes channels. If not it could possibly be a dry solder joint in the phono input. If the problem swaps channels then look at your tonearm wiring
I switched to a Behringer phono preamp and had no problem, I guess that rules out the wiring in the tonearm?
  • 1 month later...
