On 7/1/2023 at 9:13 PM, a.dent said:
Even with those compromised cables I have a totally silent background at full volume with the -120dB test track.
But you can't hear the tone, right?!
So that doesn't really tell you anything.
On 9/1/2023 at 7:24 PM, The Mad Scientist said:
The whole point of the test tone was to demonstrate to someone
It's a good test.
You will these sorts of tests in DA chip datasheets, etc.
  • Thanks 1
  • 1 month later...
  • 4 months later...
Guest georgeDV
On 25/10/2022 at 1:48 PM, Tweaky said:
It wasn't just the poor quality of bog standard Spotify that put me off streaming, I could easily throw money at the problem and get the gear you mention, or even higher level gear for that matter, change streaming services and get pretty good sound from it.
The quality of sound wasn't the deciding factor that has put me off streaming, it was a strange disconnection from the music I was listening to that I have never felt before, it's like everything has become elevator music, and consequently little enjoyment in hearing it.
I've tried to work out why I feel like this, and the only conclusion is that maybe I'm too wedded to the ritual of music playback via other means, and need that ritual to be emotionally receptive to music.
I suppose the best way I can describe how I feel about streaming is, it's sort of like if things come too easily to you , you can tend to not value them as much.
As for the often made statement of getting to hear a lot of music that you wouldn't have otherwise because of streaming, yes that is true, but a lot has been stuff that I could of happily have live without hearing as well, and have dismissed it quickly and gone to listen to something else.
And there, in a nutshell, sort of explains my problem with streaming.
I've become dismissive of so much music because it can be just thrown at you.
Hello
about streaming, for me to me. ..
I 've hade some accounts before, right now I don't have accounts for music.
I won't pay for listen 95% songs I don't like. I won't pay for songs already I have. Just a few songs sometimes I buy the iTunes track, sometimes I download it from youtube,  just a few songs, sometimes. And sometimes I open the WAV file to make it sound better.
Can you explain how you "open a WAV file", George?
Thanks.
  • Haha 1
Guest georgeDV
Thanks.
hello.
just as usual, same when import in Mac Garageband:
Open / .WAV
Thanks.
And, what’s inside? 😁
Guest georgeDV
sometimes - "inside" not exactly like opening a box, : o  !
you find clippng, or a mess of low levels, even in original tracks purchased or imported from CDs.
So how does opening it make it sound better, as you claimed?
Edited by aussievintage
Guest georgeDV
yes, there are some plugins and tools. - example I can "rescue" some high frequencies or apply a little touch of bass.
if original is really  a mess sometimes nothing to do.
Ah, so you are editing the file in all sorts of ways, not just opening it.
Guest georgeDV
18 hours ago, aussievintage said:
Ah, así que estás editando el archivo de muchas maneras, no solo abriéndolo.
: o !
not so much work or fixes. as flat as possible is better.
  • 5 months later...
I tried this experiment last night:
- JRiver buffers the signal. Set memory playback to "Load entire file into memory".
- Play music. JRiver will load the file into the buffer.
- Pull the network cable. The music will keep playing until the end of the track.
Now tell me again how the network cable and Etherregen and audiophile network switch and ANY ethernet tweak can possibly change the sound? 🙂
(EDIT) also my DAC, a Merging NADAC, has an internal buffer where all incoming audio is loaded into memory. I suspect the buffer is much smaller than my PC, perhaps a few seconds at most. The audio is then reclocked from the memory buffer and fed into the DAC chips. I haven't tried a cable pull with the NADAC yet, but I have no reason to doubt their claims.
Edited by Keith_W
  • Like 4
  • Thanks 1
when you're in the tech business and you've done the theory on digital electronics, into Digital 2H and 3H in diploma electronics, gone through  the transition of digitizing analog signals, digital transmission, processor coding and networking because it is your job requirement,  i've been banging on digital buffers in soft/hardware on these pages since these "audiophile Ethernet" began!   there isn't much that we don't know and can't measure!  I said this and i'll say it again, if i can download 30Gb via 100/20 FTTC connection through a wifi with a distance of 13m and it has to travel to another level in 15-20mins error free; not one error, there is no reason it can't do audio correctly.   You see it on these pages about " audiophile mantra on noise levels on ethernet, dirty psu etc etc  and how it effects SQ,  my take BS!  All the expensive take is really marketing at its best for a problem looking for a solution! If the hardware you use are working with in its limitations and specifications, its  extremely hard to corrupt the 2 state levels as there are steps taken to make it invincible in the transmission.  TCP/IP is bullet proof provided the hardware is within specs and operating correctly.   Notice on all these ethernet pages that everyone claiming improvements cant provide basic measurements on before and after is a dead giveaway.
  • Wow 1
I agree. There's no measured proof that "audiophile" network "enhancements" improve anything. It's all testiculation (waving one's arms around whilst talking b0ll0cks) and subjective claims of differences being heard. No one has proved any measured change in the audio signal due to ethernet switches, cables, filters regenerators etc.
Edited by The Mad Scientist
I'm having a really bad spelling day today.
It is not about error ... it is about unwanted current flows affecting DAC (or amplifier) performance.
This is possible.
... but it is not going to be audible, unless something is going reasonably wrong, either in the amount of noise, or the design of the equipment.   High speed electronics, especially where high currents are involved (computers, and computery-like-things) are difficult ... and it seems like a lot of audio equipment are just not designed with attention to this sort of thinking (eg. they seem to use very wide bandwidths and no filtering).
IMVHO, less is more.
One of the things still holding me back from releasing products (among other things) is that there is still not yet a super duper neat way to put an ethernet connection on the speaker (ie. speaker has power socket and network).
This is possible.
Goodness, Dave! You surprise me! If you are worried about current flow from the computer to the DAC, just use wi-fi or TOSlink!
  • Haha 1
thnks Keith, i was never going to reply to a post where my initial reaction is "XXX!!!!!"   🤣    and youll know what those 3 letters are!  😂
  • Haha 1
This is how converters are corrupted by anything, whether the cause be "network" or something else.
I don't think it's that common.... but if it happens, then that's how.
wi-fi
I do, not that it makes any difference on my equipment.
I use SPDIF (3-wire) between my audio player and my speakers.
Plenty of evidence demonstrates that it doesn't.
