Tonydip76 Posted June 22 Share Posted June 22 Hi, I would like to build some speakers that would be a good match for my Pioneer Exclusive C3 and M4 pre and power amps. Thinking full 12" or 15" range or 2 way. Any advice would be greatly appreciated. I am good with the woodwork... not so tuned in on the technical side of the speakers, crossovers etc. I'm going for classic 70's style look and sound. Any help will be appreciated Link to comment Share on other sites More sharing options...
The Rock Puppy Posted June 23 Share Posted June 23 Probably best if you put your question over in the "DIY" or perhaps "Speakers, etc" section. Link to comment Share on other sites More sharing options...
Tonydip76 Posted June 23 Author Share Posted June 23 Thanks man. 1 Link to comment Share on other sites More sharing options...
stereo coffee Posted June 24 Share Posted June 24 History shows the best selling loudspeaker of that era was the brand Acoustic Research. Their inventive approach, called acoustic suspension saw the lowest distortion and extended bass available, from often using smaller drivers and cabinets. Here the 3a, using a 12 inch driver, Link to comment Share on other sites More sharing options...
