I have spent some time searching, but have had no success.
I'm searching for a Hi Fi component, that can play 24bit, minimum 96KHz wav or flac files
which are on either a USB flash drive, or a memory card. I don't require the
player to carry out any other function.
All responses will be appreciated :)
The Bryston BDP 1 and 2 should be on your research list, mind you - these devices still require a DAC.
Edited by Lil Caesar
SD-TRANS, pricey though and you'll need to come up with a chassis or install it in your DAC. does DSD64-256, DXD/PCM to 384kHz. preferrable if you have an ES9018 dac to get all features. allows synchronous clocking etc.
This: http://www.astellnkern.com/eng/htm/showroom/04_showroom_120.asp
A portable player that supports up to 24bit 196kHz in the formats you mentioned. No facility for USB flash drive but it allows for two 64Gb microsd cards.  It also has 64Gb internal memory. Expensive.  It can also be used as a standalone DAC.
Red wine audio offers some mods for these too, including swapping the headphone out for a line out. http://redwineaudio.com/mods/rwak100
