Hi There
I'm trying to convert a DVD into a single  MPEG-4 file via Handbrake. When I scroll trough the Video TS folder I see there are sometimes up to three large files which all must be queued if you are to process the entire movie.
I end up with parts 1,2 and 3 of the movie in a folder which is not what I want. How do I consolidate this TS video files into one file? Is there a program more suited to this task?
You need to select the entire folder and then from the source box in Handbrake you need to select the title you want to encode Handbrake will find the files it needs, usually the longest timewise is the one to pick it can be trial and error sometimes they have multiple copies like directors narratives so always check after encoding to make sure you got the one you want.
Handbrake is one of the best free ones available it does like a powerful computer though also there are some very comprehensive tutorials on the net I found once I read these Handbrake isn't difficult to use.
Good luck
Edited by BATMAQN
Thanks, however i don't believe Handbrake has the ability to actually merge or combine 2 video files into one.
george
I have a 'Handbrake' and she's never ever had the ability to merge/combine/consolidate/queue or listen...but I have ended up with 1-2-3- and 4 parts that I don't know what to do with or use... and if there is a programme that works to control the Handbrake I'm yet to see it... :cool:
* Yeah I know: A completely superfluous post but I couldn't resist it. It's not often I see my Missus mentioned outside of the usual notices that mention that contact with this particular [enter whatever you wish here contagion/virus/extreme menace with intent] 'thing' could damage your health and/or your pocket/and or other parts of your life.
** Grab  this and see how you go, it's pretty easy to use and I've done DVD's with it with ease in to several formats.>>>>>ImgBurn
I was confused too as I'm having a few issues with my handbrake - if I gave her handful of files I expect I would get a box round the ears - the real one hurts but the metaphorical one is a bit of fun.
No it doesn't merge separate files it's main use is ripping dvds and converting those files so they are smaller I use Aimersoft to merge files together successfully.
Are you using the dvd ripper or video converter from Aimersoft?
Hmmm, when I read the title to this thread I was wondering if you were referring to your wifey. Obviously not.
And I can't help with any advise either, sorry!
Lemon curry??
DVD ripper no I don't think it gets past the encryption.
video convertor yes it's very good.
Ordinarily Luc could help with advice about how to deal with the handbrake but he is under a bit of pressure since he bought a herd of vintage amps ; )
Sean seems to be implying that he could give advice re the more universal hand brake
Perhaps he could enlighten us?
Maybe try Makemkv to extract as one mkv file, then Handbrake to convert to the format you need.
I was playing around with DVD shrink yesterday and you can re-auther a DVD and select out as single file.
Just change the extension from VOB to MPEG and then you'll probably be able to get Handbrake to do it's job.
Downloaded Ultimate Video Converter by Aimersoft. Does everything i wanted it to do and so much simpler than Handbrake. Thanks BATMAQN
Glad I could help.
I read the title and thought this was related to the little lady standing in the way of audio progress ;)
Gee, I haven't used that program (handbrake) in years.
  • 4 weeks later...
