This the question i asked a friend who is a muso, knows his sound equip:
be bad ass or just a waste of time?
so, he has told me i'll probably end up killing the stereo
this is a work project, i have a very big shed with steel slitting process lines so i need some serious sound for cheap, no really looking for good quality just loud sound, what would you guys recomend?
 i'd say the bay i need to fill with sound is 500mx150m
Your friend is right - not a good match.
The speakers might be OK, but you should get a demo first.
Look for an old Integrated Amp or Receiver with a decent power output.
you will need an array of speakers to cover all areas, unless you have a particular area that you want to serve it for.
in general big speakers like the one u posted will be ideal (think of 12" woofers and big horn tweeters), but the source and power will need to follow suit, such as pro amps with 500-1000w capabilities.
henry
Agree with the others,
those speakers should be fine, but that amp - forget it.
As Henry says, you need a pro amp for that area - but do you really need to hear it everywhere?
For that space the poor buggers close to the speakers would require hearing protection and the guys 500m away would be saying "turn it up"
Multiple speakers/amps introduces a world of pain with delays etc.
Get the speakers or similar pro style with a pro-amp at least 250W a channel and see how you go - keep the volume low enough so the guys close don't complain, and the guys further away just need to organise jobs closer to the music.
Mike
500m x 150m?!? Are you really sure? That is 5 football fields, inside one shed? I've seen some big sheds, but that takes the cake.
Seriously I've seen coal mines that don't have sheds that big ...
Edited by hochopeper
Hochopeper,
your local Bunnings must be the corner store variety...I think the Cannon Hill (Brisbane) Bunnings would be nearly that big (not 150m deep but 500m long)
and over in the west iron ore makes a truckload more money than coal over here, so the sheds are commensurately larger :)
all jokes aside that's a hell of a shed
