Mikety Posted November 8, 2021 Share Posted November 8, 2021 Item Condition: Great Shipping Options: Pickup available and you can audition.,Shipping is available at agreed cost. Suburb or Town: Sydney State: NSW Payment Method: Cash, EFT, PayPal as friends Reason for selling: Time to change Selling a combo of Pre & Power, Technics C2000 & A5000 in great condition, very nice looking and beautiful sounding. Bought these from a fellow member few years back, serving me well during the time, and now is the time to change. Note: This is 100v Japanese version so a step down transformer required. I'm willing to throw a 1000va step down transformer and a Logitech universal remote control with the sale. No original packaging so local pickup preferred but I am happy to box and ship interstate at buyer's cost and risk. Any questions, please ask. Thanks for looking! TECHNICS SU-C2000 The Technics SU-C2000, released in Japan in 1993, is a handsome high-fidelity stereo control amplifier. The SU-C2000 has a frequency response of 1 Hz to 120 kHz and an impressively low level of total harmonic distortion (<0.003% THD). Its input sensitivities are 0.15mV (MC), 2.5mV (MM), and 200mV (line). One salient feature is the unit’s virtual battery operation circuitry, which prevents interference and noise from the power source. The chassis uses THCB (Technics Hybrid Construction Base), with a hard rubber base and a copper plating chassis bottom, whereby vibrational interference is minimized. The SU-C2000 is a wonderful, quality unit with fantastic specs, a great design, and outstanding sound. SPECIFICATIONS Frequency response: 1Hz to 120kHz Total harmonic distortion: 0.003% Input sensitivity: 0.15mV (MC), 2.5mV (MM), 200mV (line) Signal to noise ratio: 68dB (MC), 88dB (MM), 104dB (line) Channel separation: 55dB (line) Output: 200mV (line), 1V (Pre out), 7V (Pre out Max) Dimensions: 448 x 129 x 344mm Weight: 9.5kg https://audio-database.com/TechnicsPanasonic/amp/su-c2000-e.html TECHNICS SE-A5000 The classAA scheme is adopted as circuitry, voltage control amplifier and electric-current drive amplifier are carried in a right-and-left channel, and it has VC-4 amplifier composition which consisted of a total of four sets of amplifier. The voltage control which determines an audio property serves as a differential-amplification input stage by a one chip Dual FET, and first class amplifier of the Darlington stream composition with the output transistor of Pc150Wx2ch, and has realized the low distortion for which the threshold of a measuring instrument is pressed. Moreover, electric-current drive amplifier which drives a speaker,It consists of a high-slew-rate swing amplification stage which allotted the feed-forward type bootstrap power supply by the FET difference input, and an output stage of Pc450Wx2ch and four-step Darlington which uses the output transistor of 3 parallel. An electric current for this to obtain powerful power is supplied at the high speed 50A/mus. A total of three transformers of two power transformers for electric-current drive amplifier of each right-and-left channel and one transformer for voltage control amplifier of a right-and-left channel are carried in the power-source part. And it has perfect symmetry composition which carried out thorough exclusion of the cross interferencee of a right-and-left channel. Moreover, the mass electrolytic capacitor with a total capacity of 89,400 micro F is carried. Specifications Power output: 170 watts per channel into 8Ω (stereo) Frequency response: 20Hz to 20kHz Total harmonic distortion: 0.007% Damping factor: 120 Input sensitivity: 1.2V Signal to noise ratio: 120dB Speaker load impedance: 4Ω (minimum) Dimensions: 480 x 207 x 475mm Weight: 34kg Year: 1990 https://audio-database.com/TechnicsPanasonic/amp/se-a5000-e.html 3 5 Link to comment Share on other sites More sharing options...
Eggmeister Posted November 8, 2021 Share Posted November 8, 2021 very nice !! 1 Link to comment Share on other sites More sharing options...
Herbs Posted November 8, 2021 Share Posted November 8, 2021 Sure does look nice! 1 Link to comment Share on other sites More sharing options...
tubularbells Posted November 8, 2021 Share Posted November 8, 2021 Classic! Those with limited budgets should really explore the vintage market as at this level of performance from a modern component you'll be paying 10x the asking price and i'll guarantee it won't look as nice as this combo. 6 Link to comment Share on other sites More sharing options...
Mikety Posted November 9, 2021 Author Share Posted November 9, 2021 On hold Link to comment Share on other sites More sharing options...
