3 hours ago, davewantsmoore said:
Calibrated...   The same SPL between samples.
Fast switching ...  There needs to be little delay between the samples.
With sighted listening of small changes with long delays between them, experts in the field of perceptual testing will tell you those results are beyond unreliable
The things we hear are illusions of the mind.
1 hour ago, davewantsmoore said:
If you're just swapping a network, with the same data ... then it (SPL vs frequency) will be the same.
For what its worth ...
It seems to me, reducing 'noise' and distortion changes how loud the output is perceived.  So, in my experience (perception) it is more 'comfortable' to increase the volume after noise is reduced.  And by doing so it is possible to hear details that were previously too low level, obscured and/or poorly defined.
Also, reducing noise/distortion seems to improve the accuracy of frequency reproduction.  In low frequencies, this can translate into less 'loudness' because the impluse response is more accurate and less bloated.  Simultaneously, the definition can improve giving the impression of more extended low frequencies, and/or increase in the volume of that new perceived extension.  To hear this, I have assembled a very good bass reproduction system, carefully positioned to suit room dimensions, etc.  This improved low end in turn improves frequencies at (as I understand it)  multiples the low frequencies, and changes how they are perceived (volume, definition and freq response).
Even though initially I don't touch the volume for a while after making a change, I will eventually change it
II without looking at the dB display to find a new volume that is pleasant to listen too.  And that varies depending on the music ... so easy to do with Devialet remote.
All this takes time (lots) and various music material to fully assimilate.  A quick A-B is possibly just the tip of the iceberg, a whiff, and possibly even no perceivable change.  So after a quickish A-B, I suggest changing the volume.
If anyone else has experienced this too, chime in.
In conclusion, it might be more valid scientifically but ...
you'd be missing out on the full benefit of many improvements if you were to keep the volume the same.
12 hours ago, MLXXX said:
As for the Ethernet network also being an important part of such exploration (in order to avoid or reduce audible impairment from noise),  the jury is out on that for many audiophiles.
Following on from above, noise in ethernet seems to colour the sound depending on how a technique or product addresses the noise.  That is important enough to me to explore it.
It is well known that an increase in SPL often sounds "good", due to a number of factors.
If you test with the SPL calibrated.... then, in your example, one will sound more "comfortable" than the other.
I'm sure you hear what you hear ... but probably settle down on the "because".  ; )
You don't need to do a "quick A-B".... if you don't want to.
But, it is well known that not doing a quick A-B will dramatically reduce your ability to discriminate between small changes.
Assuming that the overall SPL vs frequency has not changed dramatically between the samples (which is would not.... but you should check) ..... then changing the volume is a no-no, if you are trying to hear the difference between "config A" and "config B".
Changing the volume will alter the perception of the frequency balance.... mainly due to the "Fletcher Munson" effect.
You can subjectively set the volume wherever you like.....    but if you have two things that you are comparing, you cannot alter the SPL, because what you will hear is the difference in SPL, not the difference in the two things.
I say "cannot".  You can do whatever you like.... but if you want to find out what actually sounds best (ie. which is better A or B? ... or can I hear X?) ... then you should follow what I'm saying.
22 hours ago, davewantsmoore said:
There's as many ways to go about testing it as their are ways to hook up gear  ......  although to optimise the validity of the test it is good to address the things known about testing subjective perception, with how you setup the system -- and so in the end this is going to really narrow the possibilities somewhat.
I do read with a reasonable degree of curiosity posts such as yours in respect of testing regimes as you outline.  It is not something I am inclined to undertake in my own situation.  To some extent I can appreciate the enthusiasm for testing that some posters such as yourself are inclined to undertake as you suggest.  Overall I am reliant on listening to perceive benefits or disbenefits resulting from any changes that I may make from time to time
This forum is littered with many posts of reports of the experiences and opinions of posters about a range of various implementations to which perceived benefits are reported. There is no testing as you propose to support most of those reports.
John
There is.   Yes.
FWIW the Hi-Fi Immersion youtube channel has uploaded a bunch of videos "ethernet system comparison":
  • Thanks 1
On 17/12/2023 at 3:18 PM, MLXXX said:
Just a quick post to mention that I spent 3 hours today at Terry O's place on the Gold Coast, with Cafad (a very pleasant chap!) in attendance as well.
I haven't forgotten about providing further detail on the above!!  I hope to open a separate topic in coming days, where I would provide links to comparative versions of the same short extract of music (as downloaded from a lossless source, as downloaded from YouTube, and as captured with an ADC from one of Terry's systems).
Hi Steff, I see that no one else has commented on this post of yours, so I''ll have a go.
It does seem to me an odd premise: to make microphone recordings of high level systems for people to listen to with YouTube.  Given that YouTube necessarily involves use of a lossy codec at only a moderate bitrate, and also that most people would use their own streaming to watch YouTube (rather than downloading it first before watching it), how could it be expected that subtle differences in streaming performance with the equipment being demonstrated would be noticeable?  Only relatively major differences would be noticeable.
Are there any differences for your hearing?  If so could you advise which of the videos and where?  Someone could then extract the YouTube audio at relevant points, for careful A B comparison.  There's another thing: to your knowledge were lossless recordings made available as a support for the YouTube presentations?  If so, these would be the sources to use for careful A B comparisons.
Have I missed something?  I'm really at a loss to understand how it was expected that the videos would succeed in demonstrating differences for people watching the videos on their own equipment.
@MLXXX I didn't listen to it, I cannot tell minute differences between electronic components, be it DACs or elements even further removed from sound production. I simply posted the videos as a potential opportunity, your criticism of the approach is valid, of course.
I have listened to other of their recordings when they assemble high end systems, and youtube's lossiness notwithdstanding think that channel has the best mic'ing and recording methodology of "audiophile" stuff on youtube.
As to SQ differences between electronic components (ethernet in this case): some practical and generally agreed-upon descriptors would be very useful: e.g. where in the Hertz spectrum are the differences perceived, and what characterisics apply - tone, timbre, "soundstage" etc. It becomes difficult to credit discussions of marked SQ improvements brought about by discrete components when - measurements notwithstanding - the language around this remains vague. /2c
  • Thanks 1
  • 8 months later...
Some people may have wondered why I have posted so little this year.  My energy levels have been sapped by a medical condition that will soon require surgery. The survival rate for the surgery is very high but I just wanted to post very quick comments here in the unlikely event I won't get a chance to post at all in the future.
I still have the recordings I made at TerryO's place last December of his system just inside the front door of his place.  The primary recordings of interest are those taken using balanced cable connected to his amplifier; but also of interest are the simultaneous recordings using a stereo mike.  Subsequently on the net I found the same piece of music in a lossless  version, and as a lossy YouTube version.
I have received positive comments for making the effort to drive down from Brisbane to the Gold Coast region to listen to an advanced audiophile system and be afforded the opportunity to listen to sound using different Ethernet configurations.  I can report that the dominant listening experience for me was the huge difference between TerryO's casual listening setup inside the front door of his place, where I found the bass boomy, and detail in the music hard to hear, and his very advanced system in the dedicated listening room, where the sound quality was extraordinarily good, and in particular the stereo imaging better than I can recall ever hearing before in my life.
Regrettably, for the purposes of this thread,  the changes made in the Ethernet configuration were inaudible to me. Now that could be because my hearing lacks the capacity to hear subtle detail. However if I give TerryO's dedicated listening room system a subjective rating of 9 out of 10  [a very high rating]  and his casual listening system a subjective rating of 7 out of 10 [a good system for casual listening], the differences I could not hear when the Ethernet configurations were changed would appear to have been relatively small, in the overall scheme of things.
I would hope to be able to post recording extracts and and more detailed comments when my health improves, perhaps early next year.   However I doubt that anything I posted would be likely to change opinions one way or the other, on this topic of the benefits of special Ethernet cables, switches, et cetera!
Edited by MLXXX
I bought 2 bonnmx on gx and a forester fx psu + upgraded my 35m run from standard cat 6 to purist audio cat 7 plus 2 accoustic revive.
net result was more detail relaxed sound
yes its very audible and very easy to listen to for many hours with 0 fatigue ive had this going for 3 months with no changes
good listening 🎶 👌
  • 4 weeks later...
Just thought I'd share this experience.
I was having issues with my internet, most recently every week or so if would get very slow and ultimately useless (for example roon would drop out connection to Tidal a few times and then it would completely fail).  It has been gradually getting worse over many many months and I initially was focussing on my network devices (check for loose connections, power down etc - by power down I mean turned it off for a minute and back on).  By process of elimination, I discovered the solution was to power down the FTTP NTD and it would be fixed for another week or so .  After a lot of to & fro with the ISP, the symptom was latency connecting to the destination servers (apparent from Ping Tests)  and the cause was uncertain so 2 things have been done:
First a trial of a faster nbn plan.  I was on a 4/25Mbps plan and upgraded to 17/50Mbps.  Before I powered down the NTD again to make the new speed effective, Speedtest was showing 10/10Mbps rather than previously 4/20ish Mbps, so the upload was 6Mbps faster and download 10Mbps slower.
it sounded noticeably better - cleaner, basically less distortion.  General internet was also a bit more responsive.  I'm guessing my network is now doing less work because the new upload speed somehow reduced the latency to established connection to the destination.  I didn't think upload was an issue because I don't upload
The NTD eventually failed again though, and when I it power down the sound improved a bit more as I was getting 17/45ish Mbps.
Secondly, nbn then replaced the original (10yo?) NTD with the newer model Alcatel-Lucent G-240G-P.  It sounded noticeably better still - I'd say this was a bigger improvement to the faster speed.  Together, these 2 things made a considerable improvement.  It's been a week since the new NTD and no failure issues like before (maybe still to come?).
On the horizon:  In the meantime I discovered nbn is planning to roll out new NTDs:
  • a new, slimline, single-port NTD ...  speeds up to 2.5 Gbps (proposed for residential use)
  • a new, four-port model ... speeds up to 10 Gbps (for businesses).
Plans for speeds more than 1Gb will come with a cost of course.  Also, achievement of those speeds could presently be constrained by existing nbn infrastructure (until those are upgraded).
But 2.5Gb most likely has a lot less jitter and noise than 1Gb even if just facilitating 50Mbps - 10Gb certainly does.   I use a 10G Mikrotik router which is much closer to EtherRegen than 1G.   I have managed to realise considerable SQ improvement of both the old and new NTD, and the router with a variety of jitter/noise reducing things.
The only 'audiophile' network hardware I have is 1 EtherRegen and 3 ethernet cables, although there is a raft of 'audiophile' type things that make these sound/perform better.  The SQ is staggering.
More info here ... nbn accelerates multi-gigabit speed talks with retailers
The bottom line seems to be there are things outside your network that still influence what you could hear from streaming, namely:
  • latency due to what upload speed your plan enables
  • nbn NTD (which belongs to nbn)
  • possibly other nbn hardware upstream of the NTD
