Further information:
Excellent streamer. Roon ready or you can use Auralic's own Lightning DS app (iOS only) to control playback.
Unit has scratches on the bottom from being moved in/out of hifi rack. The display is losing some pixels but totally readable.
Includes remote control.
ARIES provides two individual FemtoClocks. One FemtoClock serves USB audio hosts, while the other serve all other digital outputs. Between these FemtoClocks and the unit’s outboard ‘PurerPower’ power supply module, the idea is to deliver low-noise, very low-jitter, digital audio files to your DAC of choice on a consistent basis.
Technical Specs
Streaming services supported: Local uPnP/DLNA library content; online streaming from TIDAL, Qobuz, and Internet Radio, AirPlay, Songcast, and USB hard drive files.
Supported file types: AAC, AIFF, ALAC, APE, DIFF, DSF, FLAC, MP3, OGG, WAV, WV, and WMA
Supported sampling rates: PCM: 44.1kKz – 384 kHz at 16 – 32 bits. DSD, DSD128, DSD256
Control software (and devices): AURALiC Lightning DSD software application, AURALiC RC-1 remote control (included), OpenHome-compatible software, uPnP AV software
Media Server Compatibility: Minimserver, Twonky, Asset uPnP, JRiver, DLNA/uPnP-compatible server software
Display: 3-inch 256 x 64-pixel OLED display
Digital Inputs: Gigabit Ethernet (via RJ45 jack), Dual‑Band Wi-Fi connection, USB 2.0 High-Speed for use with external USB music library drives.
Digital Outputs: USB 2.0 High-Speed for connections with compatible DACs (compatible DACs are those that do not require a driver for use with Mac OS X); AES/EBU, coaxial S/PDIF, and TOSLINK (the latter three outputs are sample-rate limited to 44.1 – 192kHz for PCM files and to DSD64).
Dimensions (H × W × D): 7cm × 25cm × 20cm
Photos:
PLEASE READ
  • You understand that a reasonable donation for selling fees is expected upon successful sale of your item
I think it does, But I use Bubble/pnp to control it via my Samsung.
I've never used the web interface other than to change the settings.
18 minutes ago, barbz127 said:
Would you know this model has a web interface so non apple users can manage/use the device?
Grab an iPad that supports the minimum Auralic iOS application doesn’t have to be the latest greatest and you are done. Ipad will give you a richer experience than your phone in regard to album art etc.
Neo
No web interface, but I use BubbleUpnP on my Andriod phone. Also, you'll need a compatible iPhone/iPad to set it up for the first time.
Just be aware that if you're trying to use an old iPhone/iPad, it works only for certain OS level upwards. I have a 10 year old iPad on which the iOS app does not work because of the older iOS version
Edited by anandpkumar
The app work on old iPad too , first you need to have same iTune account . Get the app For your iPhone fist, after it download the app to your old iPad .
it work on my fist version iPad mini
Edited by foryou
I only stream music, so I don't have a NAS or computer running. Can the app, controlled from an Iphone/Ipad allow me to stream Tidal and any internet radio?
yes for Tidal. radio? dont know
Edited by Mickstuh
