THOR PS10 PRECISE VOLATGE SMART POWER STATION SURGE PROTECTOR With Double Filtration + A12BF Smart Power Board
Variable or fluctuating power supply can affect not only performance dynamics but also the life of your components.
Designed and engineered in Australia the Smart Power Station will give you the Peace of Mind with operating parameters covering any fluctuations from 180v to 260v ensuring your equipment is only receiving what it is required (i.e., 240v.) If the voltage drops below or increases above the range, the unit will still automatically compensate and keep the voltage to stay within the safety range for your equipment.
The Thor PS10 not only protects your system against both high and low voltage surges  and damage it comes bundled with Thor’s state-of-the-art A12 triple-isolated filter with Dynamic Active Tracking. Filtering and cleaning the electrical frequency help to enhance overall sound and picture quality. It can also improve computer gaming speeds and fix internet dropouts.
When attached to the PSIO Smart Power Station the State of the Art, 8 outlet, AI2BF Smart Board delivers DOUBLE the protection and DOUBLE the filtration, incorporating Thor Dynamic Active Tracking Technology. In addition to this there are 3 isolated banks on the Smart Board ensuring there is no 'cross talk" or interference between components connected after the Smart Station.
Protects:
Ø  Top-end hi-fi and audio components
Ø  Screen technology (TVs, projectors, displays etc)
Ø  Computer and AV servers
Ø  Any device that performs better with pure power 24/7
Features:
Ø  Double filtration & double protection
Ø  Pure unpolluted 240v Sine Wave Power 24/7
Ø  Soft start: Gentle power build up.
Ø  Whisper quite servo motor for voltage calibration
Ø  Microprocessor controls
Ø  Dual LED display indicating incoming power & output power.
Ø  10 other LED alerts showing various power changes instantly.
Ø  Frontline filtering & surge protection through power station
Ø  Double filter trap & double voltage protection through custom Sway Smart Board
Ø  Incorporating Dynamic Active Tracking Filtering technology
Ø  3 in 1 bank isolation
Ø  8 outlets
Ø  Data & serial protection with Pay TV connection
Ø  Fibre optic & broadband, compatible
Ø  Updated etched aluminium fascia with illuminated buttons.
Ø  LCD updated to subtle blue with the ability to turn on/off.
Ø  6-year product replacement warranty, $500000 connected equipment warranty
Ø  Compliant with Australian standards
Ø  Designed and engineered in Australia
Ø  6 year no fuss product replacement warranty
Product Dimensions: 436mm(W) x 195mm (H) x 380mm (D)
Thor Dynamic Active Tracking Circuit - Pure Wave Form, Pure Sound & Picture
With uniquely engineered Thor technology, the Dynamic Active Tracking protection strategy encompasses self-diagnostic and corrective circuitry. As the traditional power surge protection mostly relies on simple surge absorbing circuitry at pre-defined points on the wave form, the Thor Dynamic Active Tracking monitors the sine wave, instantaneously sensing and clumping transient spikes and surges to a safe level. It additionally filters and cleans all incoming power through its 3-Bank isolation, which prevents EMI and RFI pollution as well as inter-circuit back EMF that are potentially causing audio-visual glitches and equipment damage.
SmartBrain
SmartBrain has a premium filter technology called Dynamic Active Tracking. This unique filter has the best chance of "cleaning" electrical noise because it shields around 40% more frequencies when compared to other filters. It is an Active filter and can "clean" unwanted frequencies on both the upward curve and the downward curve of a sine wave (power). Most other filters only work at the crest of the wave and therefore miss a huge section of unwanted frequencies that can generate noise on sensitive electronic devices.
Specifications - Smart Power Station:
Supply voltage: 240/VAC 50Hz
Maximum current rating: 10 Amps/2400W (Va)
Wave Form: Pure Sine Wave
Operating voltage: 180V - 260V
Incoming voltage out of designed range: (i.e.180 - 260v)
If input voltage was 270V then output would be approx. 250 to 255V
If input voltage was 140V then output would be approx. 230 to 235V
Double filtration & protection management Al2 Smart Board included
Specifications – A12 Smart board:
Supply Voltage: 240/V AC 50/Hz
Maximum current rating: 10amps/2400(VA)
Clamping Voltage: 275VAC
Reaction time: less than 1 nano second
Maximum transient spike impulse current: 208,000 A (at UL1449 standards: 52,000 A)
Maximum energy dissipation: 6080 Joules (at UL1449 standards: 2050 Joules)
Protection mode: All 8 outlets protected on all 3 circuits (Active/Neutral, Active/Earth, Neutral/Earth)
EMI/RFI noise reduction filter type: Dynamic Active Tracking 38 separate protection components in 3 cascading circuits
Multi stage filter banks: 2
Isolated banks: 3
Dedicated outlets: (4+3+1)
Total number of protected AC outlets: 8
RJ45 data protection: (1 in, 2 out)
AV/TV connection in & out (both PAL and F-Type)
Cable TV ‘F’ type connection in & out
Earth potential rise protection
Earth leakage range: less than 1 milli amp
Operating conditions: Indoor / AC Mains
Operating temperatures: -10 deg to +60 deg Celsius
