Nirvana Sound Posted August 2, 2021 Posted August 2, 2021 Callisto is an all-tube linestage suitable for the most demanding audio systems and listeners. Fully balanced circuitry from input to output, including internal balancing of single-ended inputs, results in common mode signal rejection and cleaner sound. The innovative discrete switched resistor volume control maximizes resolution at any listening level. A separate power supply chassis removes any possibility of transformer noise corrupting the delicate audio circuitry. Peter Moncrief Stealth Capacitors are used in the Eclipse Edition for unparalleled sound quality. Fully balanced differential circuitry with ability to internally balance a single-ended input signal. Innovative and unique mechanically switched discrete resistor volume control with 46 positions using Roederstein resistors. Separate volume controls and input selectors for each channel. All tube amplification and output (8 tubes total). Separate vacuum tube regulated power supply utilizing 8 tubes. Two sets of XLR and two sets of RCA outputs per channel. Six inputs: First two single-ended (rca) or balanced (XLR); remaining four single-ended (rca) only. For more information on the Callisto, contact Nirvana Sound. Don't forget to click the "Follow" button to get notified when we post about new products and upcoming events.
