Further information:
 High output 10" state of the art midrange drivers 100 Db/W/M with AIC technology (instead of shorting rings). One of the drivers has a gash on the cone and as a result the pair is priced accordingly. (these things are $500 new EACH) This gash does not pierce the cone nor is it evident on the corresponding back of the cone, so any sonic impacts should be minor.
If you are interstate its bank deposit only - msg for shipping. Comes with original boxes.
From 18sound:
The 10NDA610 is a high power, very high output, state-of-the-art midrange transducer for high quality professional use. The high level of sound reproduction is achieved thanks to extensive research by Eighteen Sound engineers, which focused on implementing mid frequencies intelligibility. The 10NDA610 is ideally used as a midrange in both horn and direct radiation, closed or reflex enclosures, as small as 4 liters. The 10NDA610 incorporates an Active Impedance Control (A.I.C.) consisting of an additional coil fixed on the pole piece and connected in parallel to the moving coil.
Photos:
Edited by Iron_monkey
