Cromer Posted July 24, 2021 Posted July 24, 2021 HALCRO LOGIC MC20 – 2 CHANNEL POWER AMPLIFIER Halcro Logic MC20 Features include: • 2-channel rack mountable or free-standing multi-channel power amplifier • 400 watts RMS continuous into 4Ohms • Unbalanced and Balanced Voltage inputs • Mains Voltage: 100-120 VAC or 190-250VAC • Remote trigger switch between On and Standby • Full control via RS232 or ETHERNET connection Command Functions: • Switch between On and Standby • Ability to inhibit individual amplifier modules • Amplifier module will indicate over-temperature condition • Amplifier module will indicate over-current condition • Transferrable warranty SPECIFICATIONS: Power Output 400W RMS continuous into 4 Ohms Frequency Response (-3db) 5 Hz-45kHz Audio Inputs, selectable Unbalanced: RCA sockets Balanced: XLR sockets Outputs Internally bridged: Binding Posts Command Functions: • Switch between On and Standby • Ability to inhibit individual amplifier modules • Amplifier module will indicate over-temperature condition • Amplifier module will indicate over-current condition • Halcro Reliability Assurance Service Gain Unbalanced and balanced 29x =29dB Power Supply Universal swtich mode Power factos corrected Fully protected Compliant in all countries Distortion THD:<0.007% at 1kHz at all powers up to 400W into 40hms 0.03% at 7kHz at all powers up to 400W Noise: <30nV/sqrt(Hz) @ 1kHz referred to input Impedance Input Unblanced: 10k Ohms Balance:10k Ohms Output Input at 7kHz <80 milliohms Power Consumption Idle: <14W 350w with 4Ohm load: 94% efficient Mains Voltage 100-250 VAC Weight: 21.1kg Height: 169mm Width: 438mm Depth: 410mm Shipping can be arranged at buyers expense 2 1
Bisguittin Posted July 24, 2021 Posted July 24, 2021 This is a magnificent amp - and keenly priced. Effortless power and fine detail. GLWTS 2
