My system is a bit to bright to me can someone help? thanks
Hello
My system before
B&W 802 D3
Emotiva XPA-1 Monoblock
Benchmark dac2
xlr cable
with that system I was not enable to listen more that 2h, with the new one is better but still to bright
My system now is:
B&W 802 D3
MCINTOSH C53 Preamp
Michi M8 Mono Blocks
Audioquest XLR cable
I listen a lot of music from computer via my dac 2 build in mcintosh preamp, when I play music on my system it is bit to sharp and to bright, can anyone help with any idea what to do, shall I get some new preamp (tube one, never hear before tube preamp) to make it more comfortable to listen ?
thank you for any idea....
best regards
  • Replies 105
  • Views 10.1k
  • Created
  • Last Reply
Top Posters In This Topic
Most Popular Posts
  • The first thing to consider might be your room. Does it sound echoey if you clap your hands? Are there carpets, curtains, and upholstered furniture or floor tiles, metal and glass? A minimalist design
  • LOL   I agree, we must have overloaded him with too many suggestions, albeit good ones!   Whilst I don’t own the 802’s, I do own the 800’s of the same version and it could be a myr
  • sir sanders zingmore
    Your preamp has a built in equaliser.  Try dragging down that 10kHz peak a bit and see if that improves things.
I had the same issue with my 804D2, and here's what I did:
https://peteswrite.blogspot.com/2013/12/how-to-make-bright-sounding-speakers.html
The first thing to consider might be your room. Does it sound echoey if you clap your hands? Are there carpets, curtains, and upholstered furniture or floor tiles, metal and glass? A minimalist design aesthetic with lots of hard surfaces can bring make for a sound that’s bright and fatiguing.
Otherwise, obviously... speakers.
One of biggest culprit would be the source, I think. And to tame the brightness of the sound, you may consider other preamps (valve or ss) and with very limited experiences with Audioquest cables, I am not really fan on Audioquest.
And, should put consideration into what @RCAJack said
What software are you using in your computer source?
A usb microphone ($100-200), and REW (free) may help you identify the issue. If it is the bowers house curve - treble boost, easy to fix with eq/dsp, although its probably the wrong speaker for you.
Changing other components is hit and miss and not a great way to "tune" a system.
With dsp you can create multiple profiles for different source material, different loudness, or simply mood. B&W respond well to eq  particularly the top end.
May I ask which Audioquest xlr cables you have and which speaker cables you use
  • Volunteer
8 hours ago, Richard said:
MCINTOSH C53 Preamp
Have you got the speakers toed in? Reducing toe-in can help B&W brightness IME.
I think they actually recommend firing straight down the room
Edited by sakabatou
typo
I've heard of a few B&W 800 series owners who feel that they are too bright.
Are you emotionally invested in them?
If not there are a whole lot of speakers out there that are nowhere near as bright as the ones you currently have, I would recommend looking into alternatives.
If so then you need to investigate the room (does it contain hard surfaces like tiles or windows), if so you could investigate rugs and curtains (the larger and thicker the better) and the gear.
I don't have any experience with any of your sources or DACs or amps so can't say if they are bright in and of themselves but I can suggest you look into brands that are generally known to be softer in sound signature such as Naim, Exposure or Audiolab.
Best of luck.
Edit:  Silver speaker cables also tend to make a system a bit brighter, they give you more treble, as do silver interconnects.  If your system is already bright then staying away from silver is a good idea.  In a vinyl or tube based system this extra treble can be a good thing, rarely is it a good thing in a digital system (at least in my experience).
Edited by Cafad
"music from computer via my dac 2 build in mcintosh preamp, when I play music on my system it is bit to sharp and to bright"
Your digital front seems not ideal yet, you have a high resolving system, source is really important, to many, source is first. If you browse this forum, many digital folks are fans of Antipodes music servers/transport from Kiwi. Discover your front end more, anyone says to know everything about digital or digital is just 1's and 0's are the one who has no experimenting or is lazy to try, or lives in remote places with less opportunity to meet up.
Would recommend you to replace your PC with a proper design transport with linear power supply (Antipodes S30/S60 for example) and a decent USB cable, check out https://curiouscables.com, highly regarded cables from Aussie. Once you can fix this weakest link IMO, then it would be good time to further tweak the sound to your liking with cables or a tube pre.  Changing speakers would be a big deal as you need to change everything again to match them, so work on the weakest link first as it is much more easy to achieve and cost less then changing system, sell/buy usually results in a considerable lost in this hobby
Edited by ikhuong
Hi Richard,
your speakers are too bright for you, and , indeed, measurably brighter than ideal. You changed the wrong components in search of a solution.
Like Sad Bastard 3 says,  you have the good fortune to have bought a (very expensive) preamp that has EQ controls, albeit crude. Based on the measurements for your speaker, you could turn down the 10kHz control by 5 dB and the 2.5 dB [sorry: 2.5 kHz] control by 1-3 dB based on listener satisfaction. The controls are too limited for precision, but better than suffering in puristic silence.
Or, since you mainly play music through your PC, apply software EQ. This can be a lot more finely tuned to your needs than the controls on your McIntosh.
cheers
Grant
Edited by Grant Slack
11 minutes ago, Grant Slack said:
Hi Richard,
Like Sad Bastard 3 says,  you have the good fortune to have bought a (very expensive) preamp that has EQ controls, albeit crude. Based on the measurements for your speaker, you could turn down the 10kHz control by 5 dB and the 2.5 dB control by 1-3 dB based on listener satisfaction. The controls are too limited for precision, but better than suffering in puristic silence.
cheers
Grant
2.5dB above should read 2.5kHz, I imagine?
Yes and thank you. I have made an edit to my previous post. Cheers
Lots of good suggestions above, especially about the front end, but another option is to look at power supply.
Power supply to the computer, DAC and pre- are really important to "brightness" in some situations.
I would suggest trying power filtering / conditioning / regeneration / new power cables and see if that helps. These should all be borrowed and tried at home.
Toric transformers have been amazing in some systems.
A simple power filter changed my Devialet 1000 system from good to amazing.
All that said, D-series B&Ws have a reputation for brightness- maybe try listening markedly off axis (ie speakers aiming straight down room or, alternatively, heavily toed-in to cross in front of you)
All the best
regards,
Edited by ICUToo
The B&W's are bright but I've heard them running before and they were fine in that setup so they can be made to sound good.
What does you room look like? Can you add any sound absorption on the side walls and rear wall?
Edited by deepthought
I sold them and got my Dynaudio C1Ps...
Hi OP
I’ve got a decent amount of experience with 800’s, particularly D3.
Whilst I understand people calling them bright, and thinking that the same at one stage, that’s not what I hear. They are not coloured like some speakers and do have a real presence up top that needs careful matching.
Current, not power, is critical in getting the best response from the bass drivers. Nothing wrong with your preamp and would have thought the Michi to be ok, although never heard one personally.
As others have said, room acoustics is critical and just as important, speaker position. I find you need to really play with speaker positioning to get the tonality right.
Try moving the speakers out into the room and closer together as this will provide some mid bass coupling and increase the midrange warmth. Toe in makes a difference too but nothing like the speaker positioning will.
Also, cables do make a difference but not your primary concern at this stage in my view.
Maybe if you provided us with you current speaker positioning and room acoustics/layout, we can help provide some more ideas.
Agreed! Room treatments!!!!!
If youre using Roon and have the skills the convolution filters work minor miracles. In my system - with b&w 805 d3 - the filters have had more impact  than a component upgrade .
In my experience B&W 800 series speakers have an artificial boost in treble so this is no doubt contributing but as per above posts you should start with your room.   Can you post some photos so we can see?  how far away from side walls are the speakers?  Do you have any treatments in the room?  Have you taken any measurements?
Moving my speakers and listening couch/chair made the MOST difference to better bass (tighter), mid range vocal transparency and further with room treatments - even just some side panels for better highs etc.
Look for a room/speaker placement calculator online to help with setup.
my couch is 1/3 from my back wall.
