PaddyMcD Posted July 5, 2021 Posted July 5, 2021 (edited) Further information: Complete powerful entry level 2.1 home theatre/ hifi setup. Ready to go. Amp, speakers & speaker cables are all What Hifi award winners. Everything (apart from subwoofer) is in pristine condition. Subwoofer has a ding on the left corner (pictured) from removal company. Doesnt effect performance. Inclusive of all cables and Cambridge Audio bluetooth adapter for wireless playback from any device. This is a great system that I have enjoyed hugely for the last couple of years and only selling due to getting a different setup. Speakers and amp are still under warranty and I have receipts. Welcome to come audition the sound and performance (after lockdown) before purchase. I would be open to selling components seperately. "Splitting available - PM me". Below I have highlighted the brand descriptions from each maker. Cambridge Audio CXA60 Int Amp (Black) & BT100 Bluetooth Receiver Power output: (2x) 60W RMS into 8 Ohms, 90W RMS into 4 Ohms DAC: Wolfson WM8740 Frequency Response: <5Hz– 60kHz /-1dB Analogue audio inputs (4x) RCA, (1x) 3.5mm MP3 input (front panel) Digital audio inputs: (1x) S/PDIF coaxial, (2x) TOSLINK optical, OPTIONAL Bluetooth via BT100 Outputs: Speakers A and/or B, 3.5mm Headphone Output, Preamp Output, Subwoofer Output https://www.whathifi.com/au/cambridge-audio/cxa60/review https://www.cambridgeaudio.com/row/en/products/cx/cxa60 BT100 Bluetooth Receiver https://www.audiotrends.com.au/cambridge-audio-bt100.html Q Acoustics 3020 Pair (Graphite Black) Like its little brother, the medium sized 3020 bookshelf speakers benefits from the advanced, low distortion, wide dispersion, new 3000 Series Concentric Ring Dome tweeter; uprated crossover and improved low resonance cabinet. In addition, it boasts a larger 5 inch drive unit, with the new Aramid Fibre/Paper cone material. This larger driver delivers an extended big bass response with fast dynamics, wonderfully open, realistic midrange and an extraordinary 'being there' three dimensional sound. * Enclosure type: 2-way reflex, Bass Unit: 125m, Treble Unit: 25mm * Frequency Response ( /- 3 dB): 64Hz - 22kHz, Nominal Impedance: 6ohm, Minimum Impedance: 4ohm * Sensitivity: 88dB, Recommended Power: 25 - 75w, Crossover Frequency: 2.9kHz * Includes: (2) Q Acoustics 3020 Bookshelf Speakers, (2) Magnetic Speaker Grills, (2) Port Bungs, (1) User Manual, (8) Rubber Speaker Grips. https://www.whathifi.com/au/q-acoustics/3020/review https://www.qacoustics.co.uk/q-acoustics-3020-bookshelf-speakers-pair.html Polk Audio Powered Subwoofer PSW303 * video-shielded * slot-loaded enclosure * 100-watt RMS amp * 8" front-firing, long-excursion driver * frequency response 35-160 Hz (-3dB) * continuously variable 60-160 Hz crossover * unfiltered LFE input for 5.1 bass * line-level and speaker-level inputs * speaker-level output * volume control * phase switch * auto on/off * real wood veneer * 11-7/16"W x 12-3/8"H x 17-7/8"D * warranty: 5 years woofer, 3 years amplifier Q Acoustics Q3000ST Speaker Stands Pair (Black) https://mrav.com.au/products/q-acoustics-q3000st-speaker-stands-pair QED Silver Anniversary XT Speaker Cable 2m pair https://www.whathifi.com/au/qed/silver-anniversary-xt/review https://www.audiotrends.com.au/qed-silver-anniversary-xt-speaker-cable-1-5-metre-custom-pair.html Mediabridge ULTRA Series Subwoofer Cable (2M) Kuitio Optical cable Edited July 9, 2021 by PaddyMcD
Zalman Posted July 5, 2021 Posted July 5, 2021 Can attest to the cxa60 will be a good while b4 I move mine on, matches with some fairly high end gear. GLWS 1
