Peppers Posted July 4, 2021 Posted July 4, 2021 (edited) Hi, I have a Paradigm Sub 12 which has been damaged and there is now a hole in the outer foam. Initial feedback from two shops is that is cannot be repaired as it has a very specific foam surround (?). I'm waiting to hear back on whether a replacement driver is available and the cost involved. The model has been discontinued for a while so I have no idea whether there would be one floating around, and if it has been sitting in storage for years it might have already degraded. What other options have I got for a replacement driver of any other brand? Can someone please point me in the direction of where I would buy a replacement driver and any suggestions of models or brands? Is something like this suitable? https://www.wagneronline.com.au/12-ultimax-dvc-subwoofer/speaker-drivers/audio-speakers-pa/um12-22-72422/1001092/pd/ This is the Paradigm model https://www.paradigm.com/en/sealed/sub-12 Edited July 4, 2021 by Peppers
muon* Posted July 4, 2021 Posted July 4, 2021 As far as a replacement goes, you need to know the specs of the existing driver to find something that matches well enough. Try Stones for a replacement consultation maybe. http://www.stonessoundstudio.com.au/stone/replacement_speaker_drivers.htm 1
VanArn Posted July 4, 2021 Posted July 4, 2021 (edited) The "Santoprene" corrugated surround can be replaced with a polyethylene foam type or possibly a rubber one. A substitute speaker that matches the parameters of the original would be difficult to find and the frame would also have to be a physical match to avoid cabinet alterations. Find a speaker repairer. Edited July 5, 2021 by VanArn Addition. 1
Peppers Posted July 5, 2021 Author Posted July 5, 2021 3 hours ago, VanArn said: Find a speaker repairer. Thanks for the replies. A repair would be preferable but so far I'm not having any luck. If anyone knows anyone in Sydney who I should be contacting, please let me know.
Fenda Posted July 7, 2021 Posted July 7, 2021 https://redirect.viglink.com/?format=go&jsonp=vglnk_162566452004513&key=416b0e142670ceb8f9f66a8c84ef71c1&libId=kqtinbqc01000bib000MLexesdsoa&loc=https%3A%2F%2Fwww.stereo.net.au%2Fforums%2Ftopic%2F109797-recommended-hifi-av-repairers-australia%2Fpage%2F12%2F%23comments&v=1&out=https%3A%2F%2Ftunedinaudio.com.au%2F&ref=https%3A%2F%2Fwww.stereo.net.au%2Fforums%2Fforum%2F21-general-hi-fi-discussion%2F&title=Recommended HiFi %2F AV Repairers (Australia) - Page 12 - General Hi-Fi Discussion - StereoNET&txt=https%3A%2F%2Ftunedinaudio.com.au%2F
