pg Posted July 3, 2021 Posted July 3, 2021 (edited) Further information: FS REGA ELICIT R INTEGRATED AMPLIFIER, WITH PRE AMP AND FINEST PHONO AMPLIFIER WITH SOLARIS REMOTE. Like New condition and needs no introduction. No box or cables. Self collect. Please contact TECHNICAL SPECIFICATIONS Power Output 105 W per channel into 8 Ω 127 W per channel into 6 Ω Input Sensitivity 105 W into 8 Ω Line Inputs (Input 1 switch set to line) 196 mV load 10 k Phono (Input 1 switch set to phono) 2 mV load 47 k in parallel with 220 pF Record Output 196 mV for rated inputs Pre-amp Output 760 mV for rated inputs Dimensions (W x H x D) 432 x 82 x 340 mm Weight 13 kg https://www.whathifi.com/rega/elicit-r/review Photos: PLEASE READ If you include any reference to pricing whatsoever in this section (excluding RRP), your ad will not be approved If you are advertising multiple items, you must post one bulk price only, or post seperate ads for each item If you don't include photographs of the actual item being sold, your ad will not be approved Edited July 9, 2021 by pg
