Sound Affairs Posted October 19, 2020 Posted October 19, 2020 (edited) Selling a traded in MS HD Power UK distributor in Mint Condition. UK sockets with Rhodium Plated Contacts. Customer trade in for PLiXiR BAC. More infos : http://mshdpower.com/products_p.html?category=sockets&class=uk&oem=1&xml=e02rh&model=MS-E02%20Rhodium Features 100% Comply with BS-1363 and BS-5733 Safety Standards Multi-Stage A/C Line Filter with PRRT Noise Suppressor Embedded Selected Premium Quality Filtering Components From Germany 6 Premium Grade Sockets High Spring Rate Phosphor Bronze Sockets Clips Pass the BS Standard 30,000 times plug IN / OUT test 1.0 µm Rhodium Quadri-Plated Coating to All Power Clips 5 mm² Power Transmission Bus Bars with 1.0 µm Pure Silver Plating Enhances High Current Flow 4mm² Silver Plated 6N OFC Internal Wires with Silver-Rich Soldering 1.0 µm Rhodium Plated IEC Inlet Adapts User-Selected Power Cords Heavy Gauge Metallic Chassis with Vibration Absorption Spikes 20A Resettable Safety Switch Protect Equipment Connected Full Life-Time Warranty Specifications Number of outlets: 6 Type of outlets available: UK Unswitched Standard mains inlet: IEC C-14 Mains Voltage : 200 - 240 VAC / 50~60Hz Max. Current : 13 Amp. Max. Wattage : 3,000 Watt (230V) Max. Surge Suppression: 2,100Joule / 72,000A for MS-E02S Rhodium only* Dimensions : 110mm x 410mm x 92mm (W x L x H) Net Weight: 2.6 KG (net) Asking for SGD$600 Reasonable offer will be considered. James. Tel : 9694 9704. (11am to 6pm, Monday to Saturday. Strictly by appointment basis, as I could be out for for installation or errands. Thank you for understanding.). Sound Affairs Pte Ltd 110 Lorong 23 Geylang #06-03, Victory Centre Singapore 388410 Edited October 19, 2020 by Sound Affairs
