kypay Posted September 14, 2020 Posted September 14, 2020 Hi, The CD door fail to open :(. Can advise me where/ who can fix this problem? Uncle Lim retired already. If DIY, which level and shop in SLT to get the parts? Thanks, Ah Pay
Goldberg Posted September 14, 2020 Posted September 14, 2020 You can contact Alfred. I send my Marantz SACD player for him to repair. Reasonable price. I found him in Carousell. https://carousell.app.link/YD8LLPDdM9
HiFi1624705803 Posted September 14, 2020 Posted September 14, 2020 You can contact Alfred. I send my Marantz SACD player for him to repair. Reasonable price. I found him in Carousell. https://carousell.app.link/YD8LLPDdM9 Yes Alfred is the guy.
Kamen Lim Posted September 15, 2020 Posted September 15, 2020 Had a very bad experience with Alfred, will not have any dealings with him anymore. Bought a used valve CDP (its European made, not cheap player) from him and later realized the cdp dac has been bypass to a cheapo, less than $10 china made dac.
YANG Posted September 15, 2020 Posted September 15, 2020 Marantz n Denon are not very uber high-end makes. Hence, from the fella's ad, u can presume that he'll not be using uber high-end components for repair oredi...
kypay Posted September 15, 2020 Author Posted September 15, 2020 Thanks for all the advice. He quote $65 with 2-3 days downtime. Discover yesterday, the CD door can manually pull out slowly, put CD, slowly push in. It is still able to play without skipping.
HiFi1624705803 Posted September 15, 2020 Posted September 15, 2020 Had a very bad experience with Alfred, will not have any dealings with him anymore. Bought a used valve CDP (its European made, not cheap player) from him and later realized the cdp dac has been bypass to a cheapo, less than $10 china made dac. what is bypass?? did he tell you that the original dac was faulty?
Eric Teh Posted September 15, 2020 Posted September 15, 2020 Thanks for all the advice. He quote $65 with 2-3 days downtime. Discover yesterday, the CD door can manually pull out slowly, put CD, slowly push in. It is still able to play without skipping. If you open the player, you will find that the tray open and close mechanism consists of a gear, plastic wheel and a rubber band. If the gear and plastic wheel are in good condition, it's the rubber band that has turned hard or stretched. https://www.aliexpress.com/item/4001146267135.html?spm=a2g0o.productlist.0.0.1c41329cBuPmmB&algo_pvid=112a03db-21ad-4633-ab51-11d06ad06476&algo_expid=112a03db-21ad-4633-ab51-11d06ad06476-0&btsid=0bb0623b16001515306502380e168a&ws_ab_test=searchweb0_0,searchweb201602_,searchweb201603_
lieu9310 Posted September 17, 2020 Posted September 17, 2020 Thanks for all the advice. He quote $65 with 2-3 days downtime. Discover yesterday, the CD door can manually pull out slowly, put CD, slowly push in. It is still able to play without skipping. the rubber belt is gone... you can try Joe (92950079)... he will do it on the spot for you ...
wyx03 Posted September 18, 2020 Posted September 18, 2020 Have had bad experience with Alfred too. Bought a pair of used speakers and found it to be broken when tested at home. There was obvious sign of touch-up to 'hide' the defect >:(
Joseph Lazaroo Posted October 8, 2020 Posted October 8, 2020 Hi, The CD door fail to open :(. Can advise me where/ who can fix this problem? Uncle Lim retired already. If DIY, which level and shop in SLT to get the parts? Thanks, Ah Pay You can contact me on H/P No:9772-1508.
Guest planet2012 Posted October 10, 2020 Posted October 10, 2020 Contact Adrian , not sure if he still repairing hi fi equipments or not. He can be contacted at 92281304.
kinger Posted October 10, 2020 Posted October 10, 2020 Contact Adrian , not sure if he still repairing hi fi equipments or not. He can be contacted at 92281304. Walking down the Memory Lane... ;D
Esquire Posted October 11, 2020 Posted October 11, 2020 Thanks for all the advice. He quote $65 with 2-3 days downtime. Discover yesterday, the CD door can manually pull out slowly, put CD, slowly push in. It is still able to play without skipping. Take out the belt and go to Koba at People's Park Centre and get a new one Try to replace it yourself and see whether it works. Just my personal opinion and disclaimer apply as usual.
kypay Posted December 5, 2020 Author Posted December 5, 2020 Thanks everyone. DIY by ordering the parts (gears & rubber band) from AliExpress. Open the CD player, discover 1 gear totally broken. Replace the whole set and close it. CD tray still cannot open. Reopen CD player again, realign 2 gear and don’t press so hard to each other. Close it... the CD player back to life!!!! Damm good experience in opening the chassis, removing 3 connectors, take out CD sliding tray & whole CD laser compartment. 2
