Audio Basic Posted August 15, 2020 Posted August 15, 2020 Dear Friends, Macro Q from Telos Audio new shipment has arrived ! Yes, It's already our 5th shipment ! It's a must for music streamer, computer, wireless and other computer music streaming devices. It appends computer’ s high-frequency noise of AC power, interfering device’ s digital, even analog signal after DAC. Bottom layer’ s Jitter is too high, it couldn’ t output the real bit perfect’ s original signal. Regardless of use any purity and material conducted only could improve slightly. Status of not any active circuits to inhibit noise, signal’ s quality will not be affect by any materials to change. TELOS MACRO QUANTUM USB active noise cancelling just like the DV Triaxial Stabilizer of USB. By detection circuit to detect noise initiative and send compensation correction signal, making irregular noise be offset synchronously, so it could offer a relatively stable USB transmission channel to offset the signal traction which causes by noise. TELOS Engineering Team uses two special IC to detect and compensate. Plug in MACRO Q, connecting with USB channel immediately, the special IC could detect random noise and make dynamic noise trap, achieving the purity of the real transmission signal, thus reduce the loss of the front to back’s transport. MACRO Q could send the currently calibrated high speed reverse signal, it completely consistent with transmission path’ s dynamic noise. As the result, only if add new digital device, or MACRO Q will maintain synchronize precision for holding signal transmission’ s high quality. Price : $380 Cheers. Audio Basic 1 Coleman Street #02-12 The Adelphi. Tel: 6338 3245
