Selling like 2  months old Linear power with dual MC3 plus USB units.
From a local dealer in Singapore.
ONLY $3000 for like new units.
Please Whatsapp me, 9776509Eight .
Original cost.
Each unit cost 1650  x 2 = 3300
LPS = 700
Selling due to DAC changed and not support external clock input.
This 2 units with LPS is good as it gets for feeding any DAC, I had some great results with  DI or DAC that accepts external clock.
From my testing,  I had it as good as feeding Mutec Refer SE120 to mutec mc3 plus.
https://www.mutec-net.com/artikel.php?id=1388254422
I have done cascase plus external clock reclocking.
Its a must try part if you are running digital source in your system.
Or
Improving your DAC even further by leaps.
Its going make your digital system sound right.
IF you always feel funny about not sounding right or center image problem.. this is a must-try.
Pls see here for the pictures.
https://sg.carousell.com/p/mutec-mc3-usb-dual-mc3-plus-chains-with-lps-units-1027503353/
The MC-3+ Smart Clock USB is setting a new benchmark for clocking technology and the reproduction of digital audio by uniquely combining an audiophile USB interface with an audio re-clocker in perfection! Particularly designed for the demands of high-end consumer audio, the device expands a new sonic universe with increased musicality, clarity, and precision. As such, the MC‑3+USB will prove its worth in many audiophile listening rooms around the world.
Unique, bit-transparent Re-Clocking without conventional sample rate conversion for purest sound quality
Audiophile, asynchronous two-channel USB interface with ultra-low noise audio clock oscillators and total galvanic isolation of up to 2500 VRMS, respectively 4242 VPK, for suppression of high-frequency interferences
Converts DSD/DoP streams (64-256) to PCM audio with selectable output clock rate
Locks to MUTEC's REF10, as well as so-called atomic clocks and GPS clock references
Improved, next-generation REVIVE re-clocking and 1G-Clock technology by MUTEC
Tested and approved to provide a consistently stellar user experience with Roon
Additional Features:
Serves as a flexible digital input switching matrix, audio format converter and master clock
Compatible to Apple Macintosh and Windows PCs
Intuitive user interface and easy installation
Update-capability via USB
Available with black- or clear aluminum front panel
Galvanic isolation up to 2500 VRMS in accordance with UL1577, respectively 4242 VPK in accordance with DIN EN 60747-5-2 (VDE 0884 part 2)
Transfers USB audio streams into AES3 and S/P-DIF and outputs those to five digital audio formats simultaneously
Converts between USB PCM audio, USB DSD/DoP audio, AES3 and S/P-DIF, as well as between AES11 and Word Clock
Highly compatible USB audio class 2.0 driver for Windows supporting ASIO, MME, DirectSound, WASAPI, Kernel Streaming, PCM 16Bit, 24Bit, 32Bit and Float-32Bit at all clock rates between 44.1kHzand 192.0kHz
Ultra-low jitter Word Clock generation with clock rates up to 1,536.0 kHz
Scalable to FS1x512 clock rates, 22,5792 MHz & 24,576 MHz, for e.g. high-end audio interfaces
Locks to Rubidium- (10 MHz), Cesium- (5 MHz) and GPS clock references
Generates Word Clocks, Super Clocks, AES3 + S/P-DIF blanks simultaneously
Uninterruptable, fail-safe clock generation in all operation modes
Eliminates so-called digital "clicks and pops"
Individual lock indicators for the clock or audio reference and the re-clock reference
USB, AES/EBU, AES/EBUid and S/P-DIF interfaces in one box
S/P-DIF interconnections via BNC, RCA and optical interfaces available as in- and outputs
Front panel lock-out for preventing of misuse
Rack-space-saving 9.5" housing
Built-in, universal power supply
