Starting (almost) from scratch - advice on building a sub $1500 system.
I've been toying with getting firstly, new speakers, then a new amp and a new player (bluray/CD/SACD plus usb input) but I think I've been budgeting too low.
I'm now looking at getting these three components as soon as I can find them all. They will complement my Rega RP1 TT, plus I have a Tuner and tape player (yep, sometimes I use it) from my current system (both Denon F-88) which I'll keep on as they get little use and probably not worth upgrading.
What can I expect to get for this kind of money? What should be considered in terms of matching the components?
Thanks for your thoughts.
Guest fordgtlover
Something like this $300:
http://www.stereo.net.au/forums/index.php?/topic/49826-fs-nad-c352-integrated-amp/
or this
http://www.ebay.com.au/sch/i.html?_sacat=0&_sop=15&_nkw=nad+3020&_frs=1
and this $320:
http://www.ebay.com.au/sch/i.html?_sacat=0&_from=R40&_nkw=usher%20s520&_sop=15
I know nothing about SACD players, but there's a Pioneer one on the bay for $380:
http://www.ebay.com.au/itm/Pioneer-BDP-150-BLU-RAY-DVD-SACD-player-MULTI-REGION-FREE-/150965036824?pt=LH_DefaultDomain_15&hash=item232637a718
Total = $1,000 for some very nice audio pleasure.
I would worry less about component matching and more on getting the best individual components for the money.
That would be my approach, but YMMV
Edited by fordgtlover
Floor standers or bookshelves for the speakers?
Personally I think more of the budget should be spent on the speakers (usher's aside- the great for the $$) and you will be able to add an S/H amp and spinner for less. $1500 is plenty to get you going.
Edited by DAMO 1147
Well I have just purchased some beautiful floor standing speakers, so that part is taken care of.
Next priority is the amplifier. Phono input is pretty much essential. I don't really want to have to buy a separate phono stage, unless the price difference is justified to have to get both units separately.
I'm re-evaluating what kind of disc player I want to get. It would be great to have something newish which plays blu ray and SACD and has a USB input for digital media. But then it throws up the question of getting a separate DAC, or an amp with something like that built in. I'm pretty sure my current CD player is nothing special, but I honestly don't know how much influence a better CD player makes. I'd rather have a more streamlined system, for financial and space reasons!
The speakers sound great with my current setup, but they've made the weaknesses in my amp completely transparent.
I'm all about physical media, so I don't think a streamer would work for me. I'm thinking a BDP (or amp) with some digital input capabilities would be sufficient for my purposes in that regard.
Thanks for the suggestion Damo I might check it out.
I've been watching what's coming up for sale here, but I've also been tempted to go down the tube pathway.
Tubes -  are great if you don't need the power, however from my limited experience i have not been impressed by cheap tube amps.  Eg Under 2K retail.  Many wiser than I have advised that the iron makes a big difference and it don't come cheap.
I'm thinking vintage solid state (cheap) or not over budget like a Rega and save up for nice tube.  Just my thoughts.
 Share
