Premium Amplifier Speaker Switch 1 / 2
Two-channel amplifier speaker switch to allow conveniently switch between speakers or amplifiers.The switch is a passive device and will not add coloring to the sounding.
Highlight:
a) Aluminum brushed outer casing
b) Toggle switch between 2 devices
c) Built using high quality high-current silver alloy 10A contact switch which has ultra-low resistance (comparable to the silver contact relay of the OMRON 30A)
d) The contact switch was soldered using 4N OFC Single Crystal Silver Plated Imported Taiwan Cable
e) High Quality Gold plated Terminal binding post.
Usage:
a) Connect 2 amplifiers to 1 speaker
b) Connect 2 speakers to 1 amplifier
Note: This switch is not suitable to use on tube amplifier which require connect to load
before turn on as it does not comes with load protection.
Selling at
1) Amplifier speaker switch 1 ($80) (Small size with small binding terminals)
2) Amplifier speaker switch 2 ($100) (Bigger size with big binding terminals)
HDMI USB Audio Extractor Decoder
The HDMI Audio Extractor can work in three modes:
    HDMI input mode
    PC-USB mode
    HDMI ARC mode
(Take note there are some HDMI audio Extractor in the market but does not support 4K and also only can support HDMI input mode.)
Feature:
- Support 1x HDMI input, 1x HDMI ARC input, 1x PC-USB input, the three signal source cyclic switching through the button.
- Support 1x HDMI output, 1 x Optical output, 1 x Coaxial output, 1x L/R output, all audio output at the same time
- HDMI support version - HDMI 1.4 & HDCP 1.4 Digital audio
- HDMI resolution - 4Kx2K@30fs,1080p/1080i/720p/576p/576i/480p/480i@24/50/60fs
- The HDMI output to HDTV support ARC audio return to the HD652A and output digital audio through Optical/Coaxial interface.
- The HDMI input audio signal, HDMI ARC audio signal, PC-USB audio signal,all support ac3/Dolby trueHD/DTS/DTS-HD/LPCM 1/7.1multi-channel audio.
Selling @ $55/pcs
HDMI Audio Extractor (3xHDMI input)
The function the same as the above except no USB input but have 3 HDMI inputs
Selling @ $59/pcs
HDMI and Digtial Audio Extractor / Decoder (with 5 channel output)
The 5.1 channel digital audio decoder can decode the Dolby digital AC-3, DTS, LPCM and other digital audio format source code, through the internal quality of DAC conversion output 5.1 channel analog audio. In support of the two output mode and a variety of EQ mode, can match with different power amplifier and speakers, to get a different sound effects. Optical fiber and coaxial digital audio output end is butted with DVD players, Blue ray machine, network player, set-top box, PS2, PS3, Xbox360, PC and many other entertainment equipment use.
How it can be use:
FEATURES:
1. Two-Ports SPDIF (1 x Optical and 1 x Coaxial and 1x USB) digital audio input, one HDMI(4Kx2K) input,  one USB2.0 interface. You can switch freely between different signal sources.
2. HDMI support version - HDMI 1.4 & HDCP 1.4 Digital audio
3.HDMI resolution - 4Kx2K@24fs,1080p/1080i/720p/576p/576i/480p/480i@24/50/60fs
4. Support 6 channel analog audio output of RCA and 1 AV video output, can be directly with the power amplifier, active sound box or TV docking
5. support stereo seven EQ mode output selection can play mode
6. support Dolby digital AC3, DTS, LPCM, HDCD, PCM, Dolby digital, Dolby Prologic II and other digital audio format decoding
7. support U-disk multimedia player, can play 5.1 channel music, video, pictures, TXT document and other multimedia content
8. DTS/AC3 decoding and playing in support of the 2 and 5.1 channel two output modes, stereo decoding playback support 2 and 2.1 output options, according to the number of flexible configuration of sound box
9. The key to switch input source, convenient operation, simple operation support panel key
10. Support infrared remote control operation and prolonged 3.5MM remote control, remote control operation can be prolonged, visual settings menu interface
11.The power-off memory function, after reboot automatically switch to the last used signal channel, USB broadcast memory before the power file
12.The use of DC 12V/1A external power adapter power supply, wide voltage can use DC (7-20V) power supply
Selling @ $95/pcs
HDMI Audio Extractor / Decoder (All in 1 Function)
How it can be use:
Features
– Support three HDMI input,one Coaxial input,one Optical input,one PC-USB input,one AUX input,one USB 2.0 input. You can switch different signal sources randomy by Button or Remote.
– Support one HDMI(ARC) output, one Optical output,one Coxial output,one 5.1ch analog audio output of RCA , all audio output simultaneously.
– All signal source(HDMI/ARC/COXIAL/OPTICAL/PC-USB/AUX/USB) can decode to 5.1ch output,it is audio decoder system.
– All signal source(HDMI/ARC/COXIAL/OPTICAL/PC-USB/AUX) but USB player can convert to COXIAL/OPTICAL output,it is S/PDIF Switcher system.
– HDMI resolution up to 4Kx2K@30hz,support 3D
– Supported audio farmat :FLAC、APE、DTS、DTS-ES、AC3、WAV、HDCD、DSD、AAC、WMV、MP3、LPCM、M4A etc.
– Support 5.1ch/2.0ch output mode,FL/FR active when 2.0ch output mode.
– Support Button or IR switch input source ,turn on corresponding LED or display on LCD.
– Support IR control operation and 3.5mm IR extending cable port.
– The power-off memory function, automatically switch to the last used signal channel, USB broadcast memory before the power-off.
– Users can be upgraded when manufacturers have updated.
– The use of DC 12V/600mA external power adapter power supply, wide voltage can use DC (7-20V) power supply
Selling @ $125(with LED Panel)    $140 (with LCD Panel)
Toslink Switches
- 3 inputs and 1 outputs for Optical/SPDIF/TOSLINK audio switch
- Supports LPCM2.0/DTS/Dolby-AC3 audio format
- Supports signal timing re-engineering
- Supports output distance up to 40 meters (130ft) when using optical fiber cable loss less 0.2dB/m
- Control input device by pressing button or IR remoter
- Supports power off memory
- Over-voltage protection prevents the wrong power adapter damaging the machine. If the standby light flashes when - charging, it indicates that the charging voltage is too high and you need to replace the power adapter at once
- LED lights indicate working status
- Lossless of quality and signal transmission
- Simple installation
- Comes with external 5V/0.5A power adapter
Selling at $35
