Audio Basic Posted March 13, 2020 Posted March 13, 2020 Dear Friends, The full ranges of JELCO TK-850 series Tonearm has arrived ! Includes the latest range of 10" TK-850M , and both 9" TK-850S and 12" TK-850L. F e a t u r e s : - Bearing for vertical direction equipped super steel metal KNIFE EDGE system. - This Knife Edge material is specially made of super steel, and have very stable and smooth operation. - This Knife Edge is precision hand made, and result is to have very low friction. - Designed Hi-mass type system, and deferent kind metal material used for anti vibration, those are very low gravity, and low gravity sound created from this. - Simple mechanism create good reproduction sound. - The tonearm geometry allows for a Baerwald alignments which is IEC recommendations. - This universal type counterweight can be used from 17 to 35 grs cartridge weight including head shell. - TK-850S is fitted with a standard head shell and can easily be changed with other standard head shell (cartridge). - This attached head shell can adjust the azimuth angle of the cartridge. Price: TK-850S 9" - S$1500 TK-850M 10" - S$1600 TK-850L 12" - S$2100 Audio Basic 1 Coleman Street #02-12 The Adelphi. Tel : 6338 3245
