Audio Basic Posted February 12, 2020 Posted February 12, 2020 Dear Friends, We are very honour being able to bring in TORQUEO AUDIO Turntable into Singapore, which they are all Hand Made in Italy ! They have made improvement and revision on their entire ranges. We are very fortunate to be one of the first to received them. We have set up one of their range, T-12H Exclusive with our HANA ML cartridge and JELCO TK-850M 10" Tonearm in our showroom ! Official Website : http://www.torqueo-audio.it NOS Motors: all the motors are subject to accurate inspection and cleaning, with complete disassembling of each single mechanical and electric part and replacement of worn or dead parts if necessary. New production motors: We use rotating stator oversized synchronous motors (external), therefore of very high precision and stability, additionally improved with ultra-silent bearings with polyamide cages. The motor/condenser coupling is carried out using the stethoscope, in fact, the phase shifter capacitor must be absolutely precise, and therefore, many must be tested until the complete absence of noise and vibrations is achieved. Mechanics: the design of the mechanisms is the result of a 3-year study and scrupulous tests. All the mechanical and structural parts are fruit of CAD design and realised in Bronze (Gunmetal), AISI 316 non-magnetic stainless steel, brass for musical instruments CuZn19Sn, top quality aluminium alloy (ergal), processed with CNC machines and very low tolerance laser. The precise calibration of all the components allows obtaining very high movement precision and absolute noiselessness. The mechanical rotation system is the heart of each turntable. Listen to music from a vinyl record that runs on an ordinary mechanical, or listen this to adisc rotating on a strictly mechanical components made without compromise and with high precision motors, are without any doubts two different experiences. We need an extraordinary mechanical to return to extraordinary performance of excellent musicians. Plinth: maximum importance is given to the structural aspects of our plinths. The aim is to model the resonance with the suppression of undesired vibrations without altering or mortifying the harmonic richness of analogue reproduction, getting a more organic and realistic sound. This occurs by using various types of very hard natural (Ipè Lapacho/Ironwood) and composite wood (Finlandian Plywood) combined with metal parts and viscoelastic materials of different hardness. Each piece is handcrafted by experienced master carpenters, using top cabinet-making techniques. In the models with natural wood, the lute manufacturing finishing techniques are used. Apart from the technical/musical and aesthetic aspects, our plinths are built to remain stable over the years. “T – Clamp” Our Vinyl Stabilizers are designed for obtaining the clearest and most detailed musical sound. They also improve the focus of the system soundstage, giving at the same time further grace and naturalness with the analog playback. Entirely manufactured with noble metals – Brass CuZn19Sn and Bronze (Gunmetal). chrome version or 18 karat Gold plated version. Weight 450 gr. Made in Italy “CU 2900” Copper Mat A solid mat from a special “4N” copper developed based on a established theory. This unique solid turntable mat eliminates the distortion-producing resonance in the 200-400Hz range. This results in a 10~20dB net reduction in overall resonance, to further reduce distortion at its source. Furthermore, the increase of the mass contributes to the stability of rotation, obtaining greater dynamic and resolution. DuPont antistatic UV protective two-component scratch-resistant finish. Made in Italy Introduction Offer Price : $21K ( Tonearm and Cartridge is optional) Audio Basic 1 Colemans Street #02-12 The Adelphi Tel: 6338 3245
