The Audio Note (UK) Quest Mono Power Amplifiers are Pure Class A Parallel Singled Ended valve amplifiers that use a pair of the highly regarded 300B triode valves per channel, producing a level of performance that is radically superior to the vast majority of current designs.
They have been specifically engineered for sonic performance rather than technical specification, and fulfill all Audio Note (UK) Level 3 criteria: –
Pure Class A operation
Zero Negative Feedback
Single-Ended Output Stage
Valve Rectification
Directly Heated Triode operation
Materials and component quality
For details : https://www.audionote.co.uk/quest
Price: SGD6390 Audio Note SG (6334 7639)
Website: https://hifi.com.sg/
audio-note-quest-1.jpg?w=600&ssl=1
audio-note-quest-2.jpg?w=600&ssl=1
audio-note-quest-3.jpg?w=600&ssl=1
audio-note-quest-4.jpg?w=600&ssl=1
