FS: DENON PMA1500R INTEGRATED AMPLIFIER WITH REMOTE AND MANUAL
ITEM: Denon PMA1500R integrated amp black in VCG
Condition:  Very good
Reason for selling: Changed my mind on my plans, rather that GLW has convinced me that I don't actually need that second system
Pics: Added
Price: $350
Additional Info:
I bought this with grand plans of getting a second system together with a pair of Usher S520's in the back room.  Trouble was that I didn't realise the GLW didn't actually want any hifi kit in 'her room' and is more than happy with the Squeezebox Boom in the kitchen.  Apparently I have enough gear in my room tokeep me happy.
This amp is in very good condition with just one small dot type mark on the volume control which can be seen in the photo.  It comes with aremote and manual.   It was a one owner before I bought it a few weeks ago.
The Denon PMA1500R and it's later cousins were a well designed integrated with twin power supples producing 70wpc in 8 ohms and 140wpc in 4 ohms.   It's a heavy item weighing 14kgs which by the way will make it too heavy for Aust Post.  It seems to be really well made with an extra thick chassis, top plate and front panel.
I've listen to it with a couple of pairs of speakers.   It's certainly a punchy amp with a revealing sound.   I probably wouldn't partner it with really bright speakers but it sounded fine with some Zaph ZD5's and Watmough standmounters I tried it with.
I don't have a box but at a pinch I could wrap it in bubble wrap and make a cardboard box to go around it.   I think it's a courier job given the size and weight.   I would have to charge for the bubble wrap as it would take quite a bit to safely wrap it up.
Specs and internal pic courtesy of Google.  The rest of the pics are of my amp.
Form Integrated Amplifier <Power amplifier part> Output power (both channel drive, CD->SP out) 70W+70W (8 ohms, 20Hz - 20kHz)
140W+140W (4 ohms, 1kHz) THD 0.01% (Output-power-3dB o'clock, 8 ohms, 1kHz) Output terminal Speaker AorB: 4ohms - 16ohms
Speaker A+B: 8ohm-16ohm
At the time of bi-wiring: 4ohms - 16ohms <Preamplifier part> Input sensitivity/impedance Line: 150mV/47kohm (Source Direct off)
150mV/13kohm (Source Direct on)
Phono MM: 2.5mV/47kohm
Phono MC: 0.2mV/100 ohms Equalizer amplifier output (Rec out terminal) 150mV of rating RIAA deflection 20Hz-20kHz±0.5dB <Synthesis> Signal to noise ratio
(at the time of A network and an input terminal short circuit) Line:110dB
Phono MM: 91dB (at the time of a 5mV input)
Phono MC: 76dB (at the time of a 0.5mV input) Tone control Bass: ±8dB (100Hz)
Treble: ±8dB (10kHz) Loudness Bass:+10dB(50Hz)
Treble:+5dB(10kHz) Power receptacle switched: Three lines, a total of 120W Power supply voltage AC100V, 50Hz/60Hz Power consumption 250W
At the time of standby: Abbreviation 5W Dimensions (a base, a knob, a terminal included) Width 434x height 134x depth of 407mm Weight 14.0kg Attachment System remote control
post-104566-0-74594300-1357428681_thumb.
post-104566-0-52062900-1357428705_thumb.
post-104566-0-55680000-1357428727_thumb.
Classic amp this with more grunt than a sumo wrestler. Absolute bargain here folks, GLWS
  • Author
Amp is sold outside of SNA.  Thanks for looking.
