Hi,
I plan want to upgrade my current LED-TV to 4K LED-TV since price is so tempting.
Currently I use Audioquest-1 HDMI cables.
Can Audioquest-1 HDMI cable handle 4k application? or
Do I need to upgrade but which HDMI cable is correct one? How to recognise whether those HDMI cables can handle 4K application?
Seeking for your advise
I shall not go into the technicalities but the short answer, "No"...u can still use your HDMI 1.4 (High-speed) cable with a 4K UHDTV.
In the same vein, if you only use it for watching movies at 24fps/30fps, this is no issue but if you intend to use it for 4K gaming that support higher frame rate like 50fps/60fps for a lag-free experience...your TV and the gaming console (which at this point even for PS4 or Xbox One sport with only HDMI 1.4 port can't truly support full bandwidth) must be be upgraded to HDMI 2.0 (though Sony claimed that it can be done via a firmware update for their PS4 in the near future).
If the second paragraph doesn't make any sense to you, its fine...just stick with the "short answer" above.
Cheers!~
I have an Oppo 103D outputting 4K signal to my Samsung 4K tv. I have tried both 10.2 Gbps (highspeed HDMI cable) and 18 Gbps (supposed design for real 4K bandwidth), both work similarly with no issues.
So I guess for now, there is no need to upgrade unless your current cable does not work.
Lest everyone forgets, HDMI 2.0 is a hardware change, there is no change in "cable" management IIRC. HDCP 2.2 is another whole beast altogether - its DRM for 4K content.
Thanks bro for advise....
How about redmere HDMI cable? I read this cable is good for long length of cable... but not sure whether it is for 4K application?
Have you used it before and encountered problem (spoil your player after used)
I have been using Monoprice Redmere cables for a long time now. Was using the Highspeed (10.2 Gbps) version. It works for both Full HD and 4K for me. Was also using an Audioquest Pearl HDMI which works fine as well for 4K even though its rated 10.2Gbps.
The 18Gbps cable I was referring to in my earlier post is also Monoprice Redmere. Just that it has a higher bandwidth range.
Imo, just use your current hdmi cables on hand. Im using 4k Panny TV->Denon 4k AVR->Nvidia Shield, it works well. Unless there is a requirement to do so which affects your playback for a 4k standard HDCP 2.2 hdmi cable, change it when it comes.
Cannot handle then change lor. Never try, never know.
Mine is old audiquest 1..maybe 1.2 version only.
Buried inside my feature wall n tv console
What will happen if cant handle
Do you have any spare ones in 1.4a around, if the buried one can't work, try the spare one from your TV to your AVR. If yes, just replace it accordingly if it is long enough. So far, I recycled my hdmi cables into my 4k setup. They are working well. I don't see a need to spend unless I hit the blank wall.
As long as your hdmi cable is a 1.4 version,  u r good to go. Dun confuse and make things complicated for yourself. Brand wise, it doesn't really matter much if your cable length is 5m or less imo.
Sent from my Note 5 using Tapatalk
From what I read on the net,  the older 1.4 cables support up to 3840x2160 resolution @ 30Hz.  The newer 18Gbps  HDMI 2.0 cables support up to 3840x2160 resolution @ 60Hz.  Nvidia Shield TV supports this output.  But I wonder if there is any content available at this resolution/Hz at this point in time.
Anyway I ordered 2 units of the Monoprice 18Gbps redmere HDMI cables to hook up my Nvidia Shield -> Denon 4K AVR -> LG 4K TV.
I was exploring HDMI cables when I first got my 4K TV. Was looking at the Audioquest range. From what I gathered, the video part of the cable is similar throughout their range. The main difference is the audio part where they add in more silver. That's all.
So if your focus is on video which is what I am doing, any basic cable can do.
Im using 3m Audioquest Cinnamon 1.4a, my TV is showing this.
A quick google revealed a local seller on the link below:
http://www.sonicsoundaudio.com/index.php?cPath=456_635_638_535_481_389_92_338_315_469
I bought mine from Harvey Norman Suntec as my sales guy whom I bought most of my electronic stuff from give me a nice discount for the cables. I am sure Adelphi and Sim Lim Square would have retailers carrying them.
How much and where did you buy bro?
Hmm... solid copper coated with silver is for audio part that's why I bought Audioquest-1 (2.5% silver) for interconnect cable between BDP to AVR but it is version 1.3 nia.
How about AVR to TV? Is QED better?
QED stated their specification clearly on their box but I am not sure about Audioquest
A lot of FAKE Audioquest product also in the market.. how to spot them  :(
I am using Wireworld now.  Ultraviolet series is good enough but of course the Silver Starlight one is better, especially for HDMI carrying audio.
(Audio)
If you intend again to hide the cables behind console or feature wall, do take into consideration how flexible is the cable. The reason why I use Redmere is due to its flexibility. Audioquest Pearl is also pretty flexible and not too thick.
