Platter Mats - Question-help
HI MWR,
I used to use the stock felt mat on my P3-24 but upgraded to the Herbies Audio mat quite a while ago now. I will never look back, it's a really good mat for the price and can highly recommend it. I was particularly impressed with the sonic differences between the two, I thought the Herbies tightened the bass up and it went slightly deeper than the felt, and the highs were a lot more detailed but not as harsh.
As to the difference between the different materials you listed, I'm really not sure as I haven't heard the others.
Good luck and welcome to the world of vinyl if this is your first TT!
Sam
Thanks for the advice and very kind of you to offer the loan of a mat I may take up up on it..
For the time being I think I'll get an El Cheapo one from Audio Trends (they have felt and cork) on my way home so at least I can play something, I have a 1970s-80s collection and haven't played for about 15yrs. I'm just after something to get started and see how it sounds. So maybe at the $25-30.00 range there probably be no real difference. Then once I've exhausted my LP collection I'll probably start buying some more.
Can't wait to try it out, I just bought it here last week , it's a Yamaha YP-D71.
Martin
Edited by MWR
HI MWR,
Sam
I second Sam - once you go Herbies way good mat - you never go back - and they are a joy to use as they look good, and never lift up with the record like felt and cork can do.
Mats definitely makes a diff mate. I replaced my stock Lenco ribbed rubber mat with an Auditorium 23 mat. Not sure what material it is made of though :)
More stable soundstage/image, deeper/tighter bass, more extended highs, further refined detail throughout. Got a bit of slippage between the mat and metal platter though. So waiting to find out best solution to resolve that!
Enjoy your tt mate!
Well I'm so disappointed with the outcome. I think it must be the poor state of my old LPs as I could hardly hear anything but snap crackle and pop! The best sound was from my very first 1972 album by Argent the rest sounded poor. I may buy a new album to see what it really should sound like.
Hi Martin, you purchased Yamaha from me. Did a bit of a rush job on wiring the headshell while you waited, maybe a good idea to check connections or fit another wired headshell & see if that helps.
Cartridge as far as I knew was ok but would examine with a magnifier to be sure. Good luck with it - let me know if I can help further.
Clive.
Hi Martin
WRT your original Q about mats, I would suggest in this order, depending on your budget:
1. Herbies
2. Cork
3. Rubber
4. Felt.
I couldn't justify the $$$ for the Herbies or similar, so I spent $30 on a cork mat from the UK. The difference was astonishing. Bass was much tighter, less muddy bottom and overall definition improved. Rubber is OK, felt terrible!
David
Hi Martin
1. Herbies
2. Cork
3. Rubber
4. Felt.
David
Thanks David,
Just bought a Rega felt one for $25.00. I'm now going to purchase a decent vinyl LP from Tivoli HiFi so I can do a test tonight you know **** in **** out ....so it's a decent new album to start with.
Martin
Thanks David,
Martin
Well, if it's Rega maybe it has better properties than the felt I have used in the past. I just thought the output sounded really dulled, withheld and distant.
On a separate note - I'm guessing you are the "Martin" who contacted me about the Pioneer I had on ebay? So you ended up with a Yamaha. What model?
D
If your vinyl is old and dirty, then a good wash will help.
Try a wash first. There is info here and all over the internet that can get you started for a couple of dollars. If it works you are ahead of the game.
If your vinyl is old and abused, nothing will help, not even the best mat.
Greg
Edited by GregWormald
D
Yes correct I am. Yamaha YP-D71 from evil c
Greg
Greg,
I'd say it's old and in some cases very abused and I think the better gear is showing up just how bad they are, apart from one album which I hardly played. We're going back to circa 1975 and an old 3 in 1 jobby.
"Thanks Clive. I think it's my vinyl. The gear I used to play it on was pretty dodgy. I'll get a new album and try it out. I doubt it's the TT etc cheers mate"
That's a shame - can vouch for the benefits of a good wash, many records I had given up on ever playing again have been magically restored to quite reasonable condition using a Knosti Disco Antistat kit.
You can always get records from Dixons recycled, Haven't had to return many from scores I have bought over the years I've been going there. Grading of vinyl is pretty accurate :thumb:
Clive.
