forbesaw Posted September 3, 2012 Posted September 3, 2012 Hi there, Just put deposit on 683 speaker package Due to radical design of my home theatre only a projector screen and speaker will be in front of me. All av stuff is chased to an alcove area to the side. I need to to mount centre B & W htm61 vertically. 1 because i hear it sounds better this way and 2 its goings to look better. Ive been told by my av dealer it would be possible to use wall brackets but would need to drill into speaker itself. Has anyone done this?, I'm willing to try or have them do it, if worse comes to worse i go with a shelf horizontally but would prefer not to. Anyone's thoughts? Regards Adrian
Dr Good Vibe Posted September 3, 2012 Posted September 3, 2012 If it's a proper bracket made for the weight of the speaker , I've done it many time's in the Museum for exhibitions. Just make sure it's a speaker unit should have four points screw points and swivel to adjust.
Guest Peter the Greek Posted September 3, 2012 Posted September 3, 2012 Was it designed to the placed vertically? (Edit: just had a look at it......I'd expect more from B&W.....yup mount it vertically - but where is the question? I take it you dont have an AT screen?....photos would be good)
RockandorRoll Posted September 3, 2012 Posted September 3, 2012 The 685s come with a pretty sturdy bracket, could ask the dealer if they have some of those. They are screwed into the back
