Item:
Price: $40 each or $70 for both
Item Condition: This item is brand new unused
Reason for selling: I no longer have the transport
Payment Method: Pickup - Cash, Paypal, COD Only pick up is fine but payments need to be cleared
Extra Info: two DV 34 LASER FROM SONY
Pictures:
Please Note: I have two replacement kits sony DV 34 laser for the audio gd transports...... This information was from audio gd
1, CD-7SE has extremely high fidelity; its SQ is neutral, It can show how good or how bad a recording is.
2, It is better not to stack gear one on top of the other , if necessary to stack CD-7SE on other gear, place a paper or other things on the other gear's top, because CD-7SE has aluminium feet.
3, Attention must be given to choosing suitable power cable, coaxial cable and output signal cable.
4, CD-7SE has automatic sleep function, we advise users to turn the power off while not using the CD-7SE.
5, If paired to low grade DACs, it may not show how good the CD-7SE is.
6. The laser's life is the same as the Philips CDM12 series, having around 3000 hours life. However, if a scratched or dirty disc is played in the CD-7SE, the laser's life will be shortened.
7, Because the shipping cost is expensive, if the laser dies, users must replace it by themselves. But this is very easy and we can offer a video to show how to change the laser assembly which costs only US$12 (our cost price).
8, The #2 coaxial output of the CD-7SE uses CAST technology to transmit digital signal, and is compatible with 99% of the DAC brands in the world without modification of your DAC. But there is still 1% of DAC brands that aren't compatible with the CAST output, so CD-7SE has another standard coaxial output (#1) that suits all DAC brands.
9, If you are not using the #2 coaxial output, you have to insert the shorting plug into the RCA socket of #2.
post-132229-0-83288100-1346650399_thumb.
post-132229-0-07130100-1346650630_thumb.
post-132229-0-75110200-1346650728_thumb.
post-132229-0-77444500-1346650832_thumb.
