WTS: Fisher RS2010, Cambridge Audio A1MK3, Yamaha RX-V795, Remote
Cambridge Audio A1 MK3 Integrated Amplifier.
Warm and sweet sound.
RP = S$320.
BNP = S$350.
Beautiful Condition. Bought from UK. Black color. 30 watt per channel.
Free Monster interconnect if buy at BNP.
collect from Bukit batok east or Science Park 1.
Black Yamaha RX-V795, support DTS/DD, full preout. very powerful 110Watt per channel.
However, my yamaha remote is faulty.
I want to sell it or trade with Marantz SR series AVR, like 4300, 5200. Cause I happen to have a spare Marantz AVR remote.
Other brand Denon or Pioneer also can, but must come with remote.
Top up can be from either side.
BNP: S$150.
Mission Vintage Big Bookshelf Speaker model 762.
8 inch driver, solid box, 120watt max power, 8ohm.
selling S$249 only.
Brand new remote control, model Rc-63CD for Marantz CD63 player.
Compatible with most Marantz/Philips/Rotel CD players.
Able to open/close tray.
Able to adjust volume level.
Selling S$19.
Meet at Kent Ridge MRT( office hours) or Bukit Gombak MRT (after 7pm).
contact 83228566.
Fisher RS2010.
Real nice vintage amp, top class amp made during 70's in Japan. 110V version, USA set.
Outlook very new, shining.
Excellent sound, powerful, detail, clear. Can power up any kind of speaker from EU, US, JAPAN.
Personal feel no weakness at all.
Selling because i have too many amps
Price S$499y. Very heavy unit.
Come with a 500 Watt step down isolated HiFi transformer, beautiful golden aluminium casing with 4 US plugs.
spec:
Fisher Receiver RS-2010
POWER AMPLIFIER SECTION
Continuous RMS sine wave power per channel  ............. 100W x 2
Power Bandwidth ................................... 20Hz/20Khz
Total Harmonic Distortion ......................... 0.06%
IM Distortion ..................................... 0.06%
PREAMPLIFIER SECTION
Input Sensitivity and Impedance
at rated output, .......................................... 2mV/50k ohm
Phono (max. input capability 1 kHz) ............ 200mV (THD 0.06%)
Auxiliary ...................................... 150mV / 100k ohm
Tape Monitor ................................... 150mV / 100k ohm
Hum & Noise (below rated output)
Phono .......................................... 76dB
Auxiliary ...................................... 90dB
Tape Monitor ................................... 90dB
Frequency Response
Phono (RIAA EQUALIZED +/- 1dB) ................. 30Hz - 15kHz
Auxiliary Input +/- 1dB ........................ 20Hz - 20kHz
Tone Control (GRAPHIC EQUALIZER) 50Hz ............ +/- 10dB
250Hz ............ +/- 10dB
1kHz ........... +/- 10dB
4.5kHz ........... +/- 10dB
15kHz ........... +/- 10dB
Loudness Contour (at 30 dB volume attenuation) .... +8dB at 100Hz
.... +4dB at 10kHz
FM TUNER SECTION
Usable Sensitivity Mono ........................... 1.7uV/9.8dBf
Stereo ......................... 4.3uV/17.9dBf
50 dB Quieting Sensitivity Mono ................... 2.5uV/13.2dBf
Stereo ................. 34uV/35.9dBf
Signal-to-Noise Ratio Mono ........................ 75dB
Stereo ...................... 70dB
Capture Ratio ..................................... 0.8dB
Alt Channel Selectivity (+/- 400kHz) .............. 80dB
Image Response Ratio .............................. 90dB
Spurious Response Ratio ........................... 100dB
AM Suppression Ratio .............................. 65dB
Total Harm. Distortion (Mono & Stereo) at 65dBf ... 0.1/0.2%
T.H.D. at 50 dB Quieting Sensitivity Mono ......... 0.3%
Stereo ....... 0.4%
Stereo Separation (1kHz/10kHz) .................... 50dB/40dB
Sub-Carrier Suppression (19/38kHz) ................ 65/75dB
AM TUNER SECTION
Sensitivity ....................................... 300uV/m
Selectivity (+/- 10kHz) ........................... 40dB
Signal-to-Noise Ratio ............................. 55dB
Image Response Ratio .............................. 50dB
IF Response Ratio ................................. 45dB
GENERAL SECTION
Power Requirements (50/60Hz) ...................... 120V AC +/- 10%
Power Consumption ................................. 400W/500VA
AC Outlets ........................................ 2
Dimensions H x W x D (Inches) ..................... 20-5/16"x14-1/4"x6-11/16"
Weight (Lbs.) ..................................... 36/16.3Kg
