Help needed with speaker cable connections
I have just had my entry level system delivered and am having trouble connecting the speaker cables. I am using an NAD C326BEE amp and Wharfedale Diamond 10.6 speakers. The speaker cables are banana plug style.
1) On the amp there is a little plastic disc in the middle of the speaker connector where the plug should go, I am having trouble removing this in a non-invasive fashion. Some friends with hifi experience have suggested I push the plug through with moderate force, but this is not working, and I am afraid I will damage something.
2) On the speakers the opening through which the plug should fit is again covered by a small plastic disc. Again it has been suggested to me that I shove the banana plug through with force but this is not working.
If anyone has experience with these components using banana plug connector I would really appreciate some help.
thanks
  • 3 weeks later...
