WTS: JPS Labs Analogue AC power cord
Guest ruzhyo
Guest ruzhyo
Like new, less then 1yr old
With box and cert, 2meters
Normal Price is $678 from Local shop.
$500 firm
Selling as no more using Pre amp
SMS 96443442 to deal.
THE ANALOG AC cord, the cousin to the above The Digital AC, is designed for the needs of low level, low power, analog style components such as solid state preamps or more resolving tube preamps (for older more laid back tube preamps consider Power AC+ or Kaptovator AC cords), phono stages and phono motor drives, tuners, electrostatic loudspeaker power supplies, basically any analog or non-amplified component (integrated amps should use The Power AC+) that could potentially benefit from noise absorption and isolation of the highest magnitude within the feeding AC line for completely quiet backgrounds.
THE ANALOG AC  is highly effective in allowing you to hear the inner detail and resolution your system is capable of providing by greatly reducing its noise floor underneath which the real music is hidden, and can greatly reduce any existing'edge or grain' in the music caused by such noise mixing with the original audio signal.
http://www.jps-labs.com/powercord.shtml#tttop
