LG 32LG50D 32" LCD TV with Built-in HDTV Tuner
This 32" LG TV with built-in HDTV tuner is now selling at $899 only by Harvey Norman at the roadshow at Funan Mall.
Comes with:
(a) Draco HDTV antenna ANT-100
(b) Free wall mounting
© 3-yr agent warranty
Good buy?
You can get 32 LG plasma for the same money I think. It's not HD but you just have to compare side by side to appreciate its superior PQ. Don't worry about the specs.  ;)
  • Author
Prefer a HD-Ready set. I have a Panasonic non-HD Plasma.... world of difference when viewing HD5. CMI.  ::)
It's your money.. Buy whatever pleases you. ;)
are you sure it comes with HDTV tuner? DVB-T at most I guess.....if not you dun really need that draco box....
  • Author
It's only the Draco antenna, not the Draco STB.
Watching HD5 on it now.
Good thing about this set is that it can also power the Draco antenna the same way as the Draco STB. Otherwise would have to find a separate power supply socket for the antenna.
interesting, didn't know such a small TV got H.264 decoder. Better choice than getting a crappy draco box :D
