IeGO Furukawa Ultra-Low Temperature Lox Acoustical Power Cable - L70530
Conductor material: Furukawa - superconductivity Copper
Ingradient: Superconductivity 99.999% copper + silvers alloy continuously galvanize technology, oxygen below 0.015ppm
Outer material: The high pulling force bears the distortion astronautics polyethylene
Sound synopsis: It's suitable to the power line, the high-purity PUM pure silver plated copper thread and the pure copper wire and the copper silver alloy in different line diameter. It has 14 independences insulator, sur- earths, attaches the monolayer to isolate the copper foil is the metallic shield, may completely be cut off the external noise disturbance, the purity reaches as high as 5n, the neutral line 7 pistils, the live line 7 pistils is, the earth alone is, mellow solid, condenses visibly, each level clearly demarcated, sounds like silk, sound field broad, the electric power conduction kinetic energy is good, may produce the columnar sound field pattern body for the equipment, line of material extremely rich characteristic. This material elegant light and the IeGO completes at present of entire product series the design for Japanese well-known magazine Chief Editor the Fukuda in 06 years most to have one of with joint forces characteristic line materials, no matter is the performance price compared to, the sound performance, the performance unfolds can match the present market each section basic level and center the is high step sound equipment. Both ends inserts matches by IeGO sound loudness Furukawa red coppers power sources US/IEC plugs, Is sure need the command to put in order the coarse thread material to go against the level sound material.
> Product: IeGO L70530 Power Cable with IeGO red copper US/IEC power plugs
> (original factory terminated)
> Conductor material: Furukawa - superconductivity Copper, superconductivity
> below 0.015ppm
> Length: 1.5M / 2.0 M
Not really an MO. but sort of a special order for this Cable since every now n then i get queries for the purchase of this cable. Price inclusive of speedpost to Singapore local address. Price will change as i follow HKD to SGD exchange rates. Pm me details of your choice and i will ask for payment & your address.
1pc 1.5m = SGD $93
2pc 1.5m = SGD $169
1pc 2m =  SGD $106
2pc 2m =  SGD $197
Hi,
Is it possible for a special order of 3.5m?
sorry nope. its factory made into 1.5m and 2m only.
  • 3 months later...
Hi DJQ, are you still dealing with this cable? I'm interested in a few pieces (including my friend). I'm also interested in the iego rca protector. Thank.
Yes i still am. but price wise not as good liao. exchange rates getting bad. just add accordingly. how many you need? i will do another RCA MO on another thread.
1pc 1.5m = SGD $95
2pc 1.5m = SGD $175
1pc 2m =    SGD $109
2pc 2m =  SGD $204
Sorry for the late response DJQ. Been really hectic the last few days.
OK, I am looking at 4 pieces of 1.5m. My friend spends half his time down in Singapore each month and will be going back south next week. Please let have your transaction requirements. BTW, how long will it take for them to arrive? Thanks.
pm you. but you didnt reply.
Cables received with thanks. Will provide a review once I've got them burned in.
Sure. no problems. i am sure you will love them. i got myself 1 too to try.
