SubWoofer cable length
Hi
I am going to experiment placing my SW next to my listening position which is approximately 32 ft (not direct route) of cable length required! Read in Hsu research website that placement at that position may provide better upper bass impact.
Just like to check with experts will this 'long' run affect signal (performance) in any way!  ??? Want to find out expert opinions before forking out some $ for the cables.
Btw, how much is a budget mono-RCA interconnect, wif a splitter, of about 30 ft long?
Many thanks in advance.
When you placed order for any of their subs they offer to sell you a 20ft length of interconnect cable to go with your purchase. So not sure whether that's an indication of the max cable length. Think you would get a better response if you enquire from them directly. They seemed very responsive and helpful too.
  • Author
Hi Vink
Thks for your reply. Oh I'm not buying from Hsu. Way over my very pathetic budget!  :-[
Hv a Wharfedale 10". Just want to experiment around.  :)
try with some cheap cable first la
Subwoofer placement and setting (vol, x-over, phase) give much greater effect than cable quality/length. 32ft is not so bad. You can try 'direct route' first if you have cable laying around.
  • Author
Yup, probably so! Dropping by LHS look see.  :)
Thks
  • Author
Unfortunately don't have cable which is long enough. Half way only! :(
Any bros staying in the east kind enough to loan?  :)
Kopi on me.  :D
Sorry TS, 'tompang' your thread. Can anyone suggest what subwoofer cable to get if buy from LHS?
Thanks.
Thanks.
Bleden 1694 if on budget or 1695 more ex.
  • Author
Hi Sonic
U know price of Belden 1694 about 30 ft length how much?
Like to have a feel of pricing.
Oh, any1 know LHS open 2day (Sunday) ?
Thks
Hi Sonic
Thks
LHS closed on SUN.
1694A around $3 to $4 per meter & Canare 75ohm RCA plug $7 each.
  • Author
LHS closed on SUN.
Ok
Many thks
Belden 1694 is rather stiff, it maybe difficult to put in a trunking with tight bend. If it is for your LFE channel, you can just get 5m thicker Daiyo interconnect available in many places, split the cable to 10m and get a connector to join.
  • Author
Ok thks. Will explore this option.
You can also buy canare cable for the sub, I think it is more flexible than the belden 1694a and equivalent as good.
Fook Lai
  • Author
Fook Lai
Sound expensive. But I'll have a look see.  :)
Thks & Cheers
If I am not wrong, it should be $3 to $4 per meter, the model I got last time should be L5CFB, not sure they still have it or not.
Fook Lai
Thks & Cheers
  • Author
Fook Lai
Ok thks. Will keep in mind.
