star77 Posted July 23, 2008 Posted July 23, 2008 Hi Guys, I just got a Yamaha 663 and wharfedale 9HCP 5.1. quite noob here and need some help with settings and also some advise. my setup is as follows: HTPC -> AVR -> LCD 1) any setting i should configure the AVR for the speakers etc? 2) what speaker settings should I start with or generally what is the recommended or most commonly use setting? 3) when I play through my HTPC, i need to set to 7.1 ch enhancer to get full sourround, is this normal? (when i run straight, seems like only the front speakers are producing sound. - not sure wat the term straight represent here). 4) the sub SW150 seems kinda weak as i do not feel much punch for movies such as transformers. anyone can advise on the sub setting? there are some switches on the back of the sub. wat setting should they be set to? 5) anything else i should be configuring? thanks.
