Hey guys i having some probs with my 32 s81 tv. I connected my tv to my com using the vga port..last time when i connected it to my lcd tv..it could handle 1280 x 1024. but now when i put that..it cant show and image..so i have to use resolutions 1024x768 which now makes my monitor screen images look damn big...also...i realise that the images like the mouse have some kinda shadow behind it..kinda like double image..and when i watch full screen movie..there is a black bar at the right side of the tv...only the right side...how to get rid of it? only way i manage to find out is using 800x600..but thats really too big already...how do i overcome this problems?
Guest jonlee
Use powerstrip to output 1366*768, which is the navie resoulution of ur samsung.
Powerstrip is actually a software. Go google for it. it allows you to output at any resolution. However it's not easy to use, so do your research first.
I just got over the black bar issue. I ran at 1024x768 and at 75hz. the black bar gone. Now only prob is the image doesnt seem to be that clear..issit cos its meant to run at 1366x768? but if i run at 1366x768 what about my monitor? i doubt my monitor can handle it. Or issit possible to output 2 diff resolutions to 2 diff monitors? anyway around that?
anyone can help me with this? really cant get it to display full screen for resolutions above 1024x768. other higher resolutions including the optimum 1360x768 also have black bars by the side..tried all adjustments..including frequency...still got black bar..issit that if i use hdmi will be better? thanks guys would really appreciate ur help.
Guys i just bought a hdmi cable. Hmm.. managed to run on 1280x1024 now =) hower only prob now..which isnt as bad as earlier on is that theres a very very slight cut off and the top and bottom..not really an issue..but was wondering how to set this properly? anyone noes?
