Guys,
The issue pertain to my RX-V657 receiver.
Went back from vacation and the first thing I do (naturally) was listen to 5.1 channel music.
That's when the problem start. It turned out there is no sound coming out from both Front left and Back left speaker. All other speaker are working fine.
First thing I did was swap the connector on the receiver to ensure that it's not speaker problem.. it's confirmed it is not as the speaker immediately emit sound.
Anybody ever has similar issues before ? I have not tried to swap to presence or B set speaker, but even then I still won't hae anything coming out from left rear speaker so that really does not solve it.
Hmm.. RX-V1800 or Onkyo 805..(drooling)
Suggest you check if it is a speaker or amp issue
Since there is sound from the front pair, plug the rears there and test
If there is still no sound then the speakers had it
otherwise yes, a new amp might be in order...
did this.. swapped left output with right output on the amp and it sounded fine.
Guess I've just got myself an excuse for upgrade.. :D
